Parallel vs. series filament supply - or another filament idea
Old 11th May 2007, 07:04 AM   #11
engels is offline engels  Israel
engels's Avatar
Default capacitive input
Originally posted by SY
if you use a capacitive input filter following the rectifier, the winding's volt-amp rating should be halved.
So what's the solution? Not using a cap after a rectifier? Or using a smaller value as speci9fied in the datasheet (0.1uF - 0.33uF)?
My plan (for the moment) is like this:
trasnformer 6V secondary -> rectifier bridge -> filter cap 1000uF/16V -> two 7806's, inputs connected, middle pin to the ground -> each output with it's own filter cap (100uF/16V) -> filaments, each 7806's output to his tube, common ground.
I've found a nice heatsink for two chips and the rest is to be mounted on a terminal strip.
Have I got something wrong?
Old 13th May 2007, 02:06 PM   #12
engels's Avatar
Default b
boink!
Parallel vs. series filament supply - or another filament ideaHide this!Advertise here!
K-502 Filament supply (or K-12M) jmillerdoc Tubes / Valves 6 18th November 2009 01:59 AM
series connection of filament in push pull output stage nhuwar Tubes / Valves 42 10th February 2007 07:27 PM
How do I bias up a constant current series filament circuit? sgerus Tubes / Valves 19 25th October 2006 12:13 AM
DC filament supply LC or CL TBM Tubes / Valves 1 7th August 2005 08:26 PM
When using a DC filament supply on a DHT... Saurav Tubes / Valves 31 18th September 2003 06:03 AM
