diyAudio Sponsor
Old 9th May 2007, 01:58 AM   #1
jarthel is offline jarthel  Australia
Default protecting a VR tube
I have built a shunt regulator using CCS + a VR150. the CCS is supplying 82mA. 68mA goes to the headphone amp and the rest to the VR tube.
My concern is that if the amp somehow stops working, it'll probably take the VR tube with it since 82mA will be passing through the VR tube which is possibly double the max rating of the tube.
Is there any way I can protect the VR tube?
Thank you.
Old 9th May 2007, 02:03 AM   #2
Sheldon is offline Sheldon  United States
Could use something like a 60ma slow blo fuse on the VR tube? But you'd have to have your preamp filaments warm before power is applied to the B+, or the fuse would go on power up. You'd also want to make sure your pre would handle the extra voltage, should the VR tube go.
Sheldon
Old 9th May 2007, 02:10 AM   #3
dsavitsk's Avatar
Why is the amp going to "stop working"? And, why bother protecting a $5 VR tube?
http://www.ecpaudio.com
Old 9th May 2007, 02:12 AM   #4
d2134 is offline d2134  Romania
Send a message via Yahoo to d2134
This is odd. Can you post the schematic, please?
Old 9th May 2007, 02:16 AM   #5
I don't know his schematic, but the concept is not odd. All the supplies using a VR tube have a current limiting (or regulating) device before the VR tube. The simplest is a series resistor. But a CCS can be used instead.
Sheldon
Old 9th May 2007, 02:33 AM   #6
This is correct!
But in this case the CCS is supplying 82mA and is not protecting the VR tube, like a regular resistor. This is odd to me. It is like using a too small resistor.
Old 9th May 2007, 02:33 AM   #7
DHT112A is offline DHT112A  United States
Old 9th May 2007, 03:45 AM   #8
electronic/electrical devices breaks down all the time. it the amp breaks down, it'll stop working.
as for the comments on the price of a tube, these tubes are not abundant locally. I believe it's different situation in the US (I looked at Ebay). So getting a replacement may take several days if I need to buy it overseas.
Old 9th May 2007, 03:49 AM   #9
Originally posted by d2134
This is correct!
how would a resistor protect the VR tube? The resistor provides a constant current.
if the amp stop working for whatever reason, the current must go somewhere and I believe the current sinks to ground via the VR tube.
maybe my understanding is wrong?
Old 9th May 2007, 03:53 AM   #10
This is correct!
The problem is not in the CCS here. Under operating conditions, he is only passing 14ma through the VR tube. That's on the low end of what I've seen recommended here. The consensus (if there is one) seems to be that you want to run the VR tube around half of maximum with about an equal amount of current to the amp.
The problem in this situation, is that the amp draws 68mA. So the current source (resistor or CCS) has to deliver that, plus some for the VR tube.
Frankly, I'd make sure the amp is safe if the VR tube fails, and not worry about the VR. Make sure the voltage after the CCS cannot go too high for the amp.
The other option, assuming that both channels are driven with one CCS and VR at present, is to add a second VR and CCS and power the channels separately. Then you can get the current down near the limit of the VR if the amp is not drawing current. Voltage consideration for the amp safety still applies.
Sheldon
Protecting a microcontroller rtarbell Parts 10 11th January 2008 01:23 AM
Protecting tweeters while testing irb Multi-Way 3 22nd March 2007 09:16 PM
why is my amp protecting? mbugua Class D 2 19th January 2007 12:58 PM
protecting mosfets in UcD zilog Class D 10 12th November 2006 07:52 PM
protecting my speakers from my GC damitamit Chip Amps 13 16th June 2003 03:46 PM
Page generated in 0.10328 seconds (89.05% PHP - 10.95% MySQL) with 11 queries
