| diyAudio Sponsor | ||
Hello,
This is my first post here, though I already got much help for reading many useful talks going on. I just ordered and got a Meixing 3008ab amp(they say it's newer version which uses 2a3 instead of 300b as driver tube), and very much satisfied with its sound even in its original state. But there are many problems. As this is my first tube amp, I got somewhat perplexed. 1) There comes some noise in speakers whenever I power on. No noise when power off. Is it normal for this amp? 2) There is a slight hum in the transformer. I saw a few users of this amp faced similar problems. How can this be fixed? 3) The transformer got hotter and hotter, and after 5 hrs became almost impossible to touch. Is it also normal? Sorry for many questions. Thank you in advance. Hyun |
#2 |
Check that the amp is set correctly for the line voltage in your country.
If so, make sure you use it in a well ventilated area so that you get good airflow around that transformer and the tubes. Check the securing bolts for the transformer are tight. If so you may need to actually undo the bolts and fit some vibration damping material between the transformer and chassis - make sure you retain a good earth connection to the transformer metal parts. What is the noise from the speaker at switch on. Is it just a single thump? or a hum? and how loud. If its a single thump and is not very loud then its not something you need to worry about. Hope this is of so help, Cheers, Ian |
#3 |
Hi ! I am now is just talking about the transformer hot. You mean that you can not touch the trans. after few hours working ? I think :
- That trasformer is overload - That transformer is sub standard , tell us transformer specification. I think, however, the transformer get hot is normal if temperature is not exceed temperature range in specification. If it is lower than 70 celcius degree -> OK. Regards. Boeing. |
#4 |
Thank you, Ian and Boeing for your kind and detailed reply.
I think I solved one problem. There is a "protective switch" on the front panel of this amp. Until now I always have this switch "on", but the noise is gone when I power on with this protective swicth "off" !! Actually I sent at least 2 emails requesting the role of this switch to Meixing audio, but got no answer at all. I hope this helps the users of this gorgeous amp. Anyway, the hum on the transformers continues. Hyun |
| Meixing MingDa MC767-RD | gorogoro | Tubes / Valves | 12 | 9th December 2009 05:47 PM |
| MeiXing MC-805AA biasing | audiomatic | Tubes / Valves | 2 | 25th March 2009 08:42 PM |
| Found Meixing Amp schematic, sorta, would like some feedback | pjpoes | Tubes / Valves | 3 | 4th March 2007 04:22 PM |
| meixing 805 tube amp problems | pjpoes | Tubes / Valves | 11 | 21st October 2006 02:54 PM |
| Modding MEIXING MC 3008 | pjpoes | Tubes / Valves | 1 | 10th October 2006 10:57 PM |
| Page generated in 0.09458 seconds (73.63% PHP - 26.37% MySQL) with 10 queries |
