| diyAudio Sponsor | ||
it seems these are not connected to the internals.
thank you. |
#2 |
Structural support
#3 | |
if that is all its purpose, why can't they just have the pins without the wires connecting 3 and 7? |
#4 |
These pins have a real use. In many regulator circuits the output voltage will run away if the regulator tube is pulled out while the circuit is operational. The intent of the jumpered pins is to shut the power supply down if the tube is removed. This is pointed out in some tube manuals and data sheets. The RCA RC-30 (AES reprint) page 116 shows these pins wired is series with the line voltage supply. This explanation is offered:
"Removal of tube from socket removes voltage from load."
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#5 | |
Sheldon edit: can't think fast enough. Tubelab beat me to it. |
#6 | |
#7 | |
Sheldon |
#8 | |
| Care and Feeding of Tube Pins / Sockets | gingertube | Tubes / Valves | 18 | Today 06:39 PM |
| Help cleaning tube pins | astouffer | Tubes / Valves | 10 | 11th December 2007 08:51 AM |
| Multi-purpose tube amp (line and guitar inputs) | smsmonster | Tubes / Valves | 28 | 20th May 2006 01:12 AM |
| Miniature 8pin socket | thomasholley | Tubes / Valves | 4 | 29th February 2004 04:10 AM |
| Cleaning oxidised tube pins. | JoeBob | Tubes / Valves | 18 | 21st August 2002 04:18 AM |
| Page generated in 1.84490 seconds (-73.96% PHP - 173.96% MySQL) with 10 queries |
