diyAudio Sponsor
Old 7th May 2007, 07:01 PM   #1
arhi45 is offline arhi45  Romania
Default the hybrid one
Hello all,
I found on the web here:
http://www.diegobarone.it/
this schematic
The author says it has 8 watt of power, 10 to 50KhZ bandwith.
Has anybody tried it?
Thanks all!
Old 8th May 2007, 04:42 AM   #2
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
I'm sure with the right part types and values it will do as claimed or more. The only thing that strikes me as odd with that design is C3. Suppose it's some sort of bootstrapping, but it's a type I've never seen and don't know if it would work. I would think that it could be prone to oscillation. But then again I'm not the most knowledgeable guy.
Old 8th May 2007, 07:21 AM   #3
Miles Prower's Avatar
That's exactly what C3 is: a bootstrapping capacitor intended to elevate the input impedance of an emitter follower. It's usually done with small signal stages, however. Not too certain just how much you can raise the input impedance of that design. It looks like it's gonna be one tough load for that SRPP.
Also, it doesn't have any sort of bias stabilization, and will probably be susceptable to thermal run-away.
I wonder if it wouldn't be a much better proposition to substitute a power MOSFET for the BJT, as a parafeed source follower.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 8th May 2007, 08:31 AM   #4
My italian is more aproximate than my english but i think he says thay you can replace the igbt with a mosfet:
.....classe A (quindi è linearissimo sui piccoli segnali e si comporta egregiamente anche per livelli di potenza più elevati) e fa uso di un IGBT ( ) (il GT20D101 TOSHIBA, costruito espressamente per l’uso audio) ma nessuno vieta di provare anche con dei MOS (per esempio gli IRF540 sono eccellenti in questa applicazione....
the values here:
Reference Descrizione
R1 Resistenza 100k 1/4W
R2 Resistenza 390 1/4W
R3 Resistenza 470 1/4W
R4 Trimmer 470k
R5 Resistenza 10k 1/4W
C1 Condensatore poliestere 1*F
C2 Condensatore poliestere 1*F
C3 Condensatore elettrolitico 2.2*F 25V
C4 Condensatore elettrolitico 10000*F 25V
L1 Induttore 50mH 2A
T1 GT20-D101
V1 ECC88
Old 8th May 2007, 03:13 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I am afraid it is easy to burn a choke and output transistor because of a thermal runaway.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 8th May 2007, 03:41 PM   #6
plovati is offline plovati  Italy
Default translation service :-)
it means (more or less)
"is a classa A amplifier (so it is very linear on small signals and it performs very well also for higher power levels) and it use an IGBT (GT20D101 TOSHIBA, expressely designed for audio use)
but nobody forbids to try also MOSfet (for example IRF540 are excellent for this application)
The name of the project instead is a little joke beacuse HybridOne suggest ibridone, in italian a big hybrid.
Apart from that, no technical comments, sorry.
Piergiorgio
Old 8th May 2007, 03:56 PM   #7
kevinkr's Avatar
The device used is an IGBT - an insulated gate bipolar transistor, which with bootstrapping as shown should be a pretty easy load to drive. IIRC it's thermal stability is quite similar to that of a mosfet, although I cannot attest to the specific device.
I haven't the time to read the entire thread at the moment including the Italian parts (which I can read), but why not build it as specified with the specific parts recommended and see how it works?
www.kta-hifi.net
Old 8th May 2007, 04:16 PM   #8
Wavebourn's Avatar
I would add a DC current sensing something through the choke (adding some low ohm resistor in series with it) that adjusts voltage on the gate accordingly. For example, an integrator using one opamp, in such case it will be temperature stable, otherwise I'm afraid to load an emitter follower by low DC resistance of a choke. Also, reverse connected diode between collector and emitter would not be odd in case you forgot to connect a speaker.
Old 8th May 2007, 04:52 PM   #9
kevinkr's Avatar
Here is just the first page of the spec sheet for the GT20D101.
Input capacitance is pretty high, soa looks pretty much like a conventional bipolar. Vge of 3V gives a collector current of about 2A, 3.5V about 6A.
Some sort of bias servo probably is a good idea, but with a large heat sink and low Vce might be dispensable.
www.kta-hifi.net
Old 8th May 2007, 06:22 PM   #10
Wavebourn's Avatar
Servo is cheaper.
Hybrid Car Amp... let's try jeppix Car Audio 19 18th August 2008 05:48 PM
Hybrid Amp alpine67 Tubes / Valves 7 28th May 2008 12:53 AM
Hybrid Ply / MDF ? Renron Multi-Way 5 8th February 2007 10:49 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Page generated in 0.10362 seconds (88.32% PHP - 11.68% MySQL) with 11 queries
Copyright 1999-2012 diyAudio
