diyAudio Sponsor
Old 5th May 2007, 05:45 AM   #1
sorenj07's Avatar
Default 5763 = El84?
The basic question. Saw 5 on the 'Bay for $11 or so including shipping. Can I use these as EL84's? The information on these is sketchy at best. Here's a nice picture showing the similar-sized plate structure, though that of the 5763's is nearly continuous. P.S. those blue blurs in the background of the macro shot are a nice shiny pair of 7600 ohm 25W Edcors. I'm building an amp for a friend's family and at the moment have some 6P14P's that might or might not be working, and now this "sleeve" of 6 (the seller threw an extra one in) that could hopefully work.
The amp will have a B+ of 385 or so, and my cathode resistors are 182 ohms and half of a 100-ohm pot per PP pair. My bias point using an EL84 UL datasheet is ~240V plate, 35mA. Dissipation is 8.4W. I imagine that to use the 5763's I'd want some healthy grid stoppers to the inputs. Would I also want to put big screen resistors? One PDF I read suggested that for a 300V screen grid voltage in RF use, a 12.5K resistor ought to be used. Finally, I'd probably strap pins 3 and 7 together, namely the 3rd grid from the cathode and the cathode, right?
Thanks!
As promised:
Old 5th May 2007, 06:47 AM   #2
coresta is offline coresta  France
coresta's Avatar
Hello, yes , i asked myself the same question and have just done a test on my Metrix toobz tester . The 5763 seems to be a perfect sub of the EL84 . One caveat : It's a real TETRODE, not a pentode but, as you previously said , original RF. So the G1 might be a reinforced one , against secondary emission in C class . I've sold myself 50 pieces on epay in the last months as i have a huge stock of them ... So it is worth a try . ON AA , a guy claimed he tried it in an AF amp without any problem. I have the project to build an OTL amp with 24 5763 / channel Yes 48 5763 in STEREO
Old 5th May 2007, 06:58 AM   #3
sorenj07's Avatar
Sounds great! Also, I found this in a PDF:
tp://www.vacuum-tube-shop.com/vacuum-tube-shop.pdf
We are made amps whits can pull out 20W audio power whit one
pair. Transformer designed for EL84 can be applied to quartet
of 5763. Matched quartets should be no problem.
Aside from the Engrish, looks promising! I'll definitely give them a shot.
Old 5th May 2007, 12:44 PM   #4
SY's Avatar
Dumb question: since you can get excellent quality real EL84 for about the same price, why do this at all? Or was that $11 for all five rather than $11 each?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 5th May 2007, 04:52 PM   #5
sorenj07's Avatar
$11 for six, the guy threw in a sixth one on top of the sleeve I bought. that's really the only reason... I saw an EL84-ish power tube, checked and saw its 13.5W plate dissipation, and BING! ordered it.
Old 5th May 2007, 06:04 PM   #6
SY's Avatar
Got it!
Old 5th May 2007, 07:12 PM   #7
Default O T
Who's your icon, SY? He looks like a Gilbert Shelton character.
Poinz
Old 5th May 2007, 10:01 PM   #8
SY's Avatar
Exactly. Phineas Freak of the eponymous Brothers.
I'm a major Wonder Warthog fan. Philo T. Desenex, the Hog of Steel.
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 Yesterday 08:38 PM
5763 Triode Strapped wrenchone Tubes / Valves 3 5th August 2006 06:59 PM
5763 tetrode on OTL ? coresta Tubes / Valves 1 15th March 2006 12:53 AM
PPP EL84 Amp Peter Menting Tubes / Valves 8 24th August 2005 05:34 AM
Page generated in 0.10062 seconds (80.01% PHP - 19.99% MySQL) with 10 queries
