diyAudio Sponsor
Old 4th May 2007, 04:11 PM   #1
cloud is offline cloud  United States
Default "12EA6" Pentode !
Has anyone ever used or built a PP or SE amp using the 12EA6 tube's often found in old car radio's ? If so please give detail's ect...
Old 4th May 2007, 11:43 PM   #2
Miles Prower's Avatar
These look pretty useless as audio finals. Given a Vpk= 12.6Vdc and an Ipq= 3.2mA, you'd be looking at outputs of mere microwatts.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 5th May 2007, 05:08 AM   #3
Can the 12EA6 be used in some other way ? I have 6 NOS of them which my grand-father never used from the 50's, he was a car buff of sort's.
Old 5th May 2007, 05:53 PM   #4
Since it's a small signal tube, about the only thing it's good for would be a preamp. either that, or try to find someone who's into restoring old VT car radios and trade for something else.
www.dolphin-hsl.com
Old 5th May 2007, 08:23 PM   #5
Building a pre-amp sound's like a really good idea ! Can you point me in some kind of direction there? My first thought was maybe some type of low voltage headphone amp ect...
Old 5th May 2007, 09:30 PM   #6
tubelab.com's Avatar
You need to look here!
http://www.diyforums.org/millett.html
Sorry; I realized after I posted that my dyslexic eyeballs got the A and the E mixed up.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 6th May 2007, 12:44 AM   #7
Having very little electronic's knowledge, I have been looking at pentode data sheet's! From most pic's internally they all look to be quite similar, only difference seem's to be the pin out's ect... My question is if finding a low voltage circuit for say a SE amp is it possible to re-configure pin layout to make these tube's work? It sound's crazy but is it possible ?
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 05:56 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
suggestions for the "lowest noise" pentode Majestic Tubes / Valves 6 1st December 2004 09:42 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.08384 seconds (73.17% PHP - 26.83% MySQL) with 10 queries
