diyAudio Sponsor
Old 3rd May 2007, 11:50 PM   #1
dsavitsk's Avatar
Default Choke input PSU, drawbacks?
In one of my amps, I have a pi filter followed by a voltage regulator. I have been using some largish resistors to drop lots of volts in the PS as the power transformer is a bit large. I ran some simulations with Duncan Amps designer, and found that using the parts I have, but switching to a choke input PS, I can essentially lose all of the large resistors and replace them with small ones (from 500R to 20R). Aside from taking out the large resistors, it will also lower the voltage dropped across the regulator which seems like a good thing.
My experience so far with this amp is that different rectifiers sound hugely different, and in general, the more volts they drop (and thus the less the regulator drops), the better the amp sounds. I would guess this has less to do with the tubes, and more to do with very hot mosfet regulator.
So, are there drawbacks I should know about here? The choke on the input will be the only choke in the PS, in case that is important.
http://www.ecpaudio.com
Old 4th May 2007, 12:08 AM   #2
I'm curious as to the topology of the amp. Regardless of that though, I can't see how choke input could ever be a bad choice if you have voltage to spare. I'm interested to see what others have to say on this excellent topic. Thanks, Jay
"Make everything as simple as possible, but no simpler" Einstein
Old 4th May 2007, 12:30 AM   #3
jarthel is offline jarthel  Australia
from what I have read, the only drawback to choke-input are:
1. the lower voltage (according to an article from audioexpress turorials)
2. chokes are more expensive than resistors (my reasoning)
3. size if space is limited (my reasoning)
Old 4th May 2007, 12:44 AM   #4
Tom Bavis's Avatar
With solid state rectifiers, you would have to think about protecting them from inductive spikes - no need with a tube. You WILL lose some filtering with one less cap, of course, but if you're regulating afterwards, no big deal.
Old 4th May 2007, 05:31 AM   #5
Tweeker is offline Tweeker  United States
Be sure to size the chokes current capacity such that it can handle the AC ripple current present in addition to its DC load.
VinRMS/1386/L= ma AC ripple 60hz mains.
Be sure your foil hat has a good low impedance ground.
Old 4th May 2007, 08:18 AM   #6
Shoog's Avatar
Two issues you might encounter. If the amp takes longer to come up than the power supply, the choke will drop out of the power supply and the voltage will rise as if it wasn't there. Of course this will drop back down once the amp starts drawing current. An appropriately sized bleeder resistor will help to minimise this effect.
Secondly you could experience ringing between the power transformer and the choke. This will probably manifest as overheating of the power transformer. This is a problem I encountered when I used a choke input filter to bring a 900-0-900V transformer down to 700VDC.
Shoog
Old 4th May 2007, 09:17 AM   #7
You can check for likely ringing in PSUD II with a stepped load. Reducing ringing involves using more capacitance and/or resistance in the LC filter. Im not sure about ringing in the PT though, this is for ringing in output voltage due to transients.
Old 4th May 2007, 10:11 AM   #8
diyAudio Moderator Emeritus
ray_moth's Avatar
It's common to use a bleeder resistor to ground after the choke, if the load is variable, to ensure that the choke does its job even with light load. Also, with variable load such as that imposed by class AB or B amplifiers, the choke may need to be a swinging choke (a choke with a smaller than usual air-gap in its core), so that its inductance falls with increasing current to improve regulation.
Old 4th May 2007, 11:58 AM   #9
Swinging chokes tend to be a custom item these days, youl still have better regulation than a CLC filter regardless.
Swinging chokes also dont need as large a bleeder.
Old 4th May 2007, 05:35 PM   #10
dsavitsk's Avatar
Thanks for all the comments. I switched the PS around last night and everything seems to work pretty well. Sound wise, I am not sure I noticed much change, though switching from a Sovtek 5ar4 to a Mullard one did seem to smooth things out a bit. But, the whole amp runs cool, other than the tubes of course, but the transformers and top plate are all staying cool.
One potential problem is that ripple before the regulator went from 100uV to about 100mV. (Previously, this was a RCLCRCRC filter before the reg, now it is a LCRCRCRC.) This is a headphone amp, and this was enough to create a very slight audible hum. So, I may need to bump up the filter caps a bit.
-d
Choke Input Filter. G Tubes / Valves 8 11th February 2008 08:57 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Input Choke Too Small dre7 Tubes / Valves 1 29th September 2007 10:35 PM
SOZ Choke input filter? gnomus Pass Labs 48 14th May 2004 06:41 PM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 04:59 AM
Page generated in 0.09277 seconds (82.99% PHP - 17.01% MySQL) with 10 queries
