diyAudio Sponsor
Old 3rd May 2007, 12:43 AM   #1
alexg is offline alexg  Philippines
alexg's Avatar
Default 7193 (2c22) preamp buzz/hum
I built a 7193 (21c22) preamp using plate chokes.
It is very quiet and sounds great. After using it for about 40 minutes to 1 hour, it will develop a buzzing/humming sound present in both the tweeters and the woofer, it is quite loud, can be heard from 1.5 meters from an 87db speaker. The buzz/hum is present on both channels.
The 7193 has two "horns" for the anode and grid on top of the tube envelope and I just used ordinary teflon insulated wires on it. The PSU is a CLCLC regulated using an 0D3.
I suspect the hum/buzz is coming from the PSU since it is present in both channels.
BTW, am using an SE KT88 amp using Mikael Abdellah's circuit.
Any suggestion/thoughts would be appreciated.
Thanks.
Old 3rd May 2007, 10:33 PM   #2
kevinkr's Avatar
Do you have an oscilloscope or access to one?
Problem could be due to a variety of causes, possibly the pre-amp is marginally stable and after that elapsed time the transconductance becomes sufficiently high or some other parameter changes causing the 2C22 to oscillate.
I would not be surprised to find that it is oscillating at VHF and the buzz you are hearing is the audible manifestation of that. Try an AM/FM portable radio or even tv set near the pre-amp and see what if anything you pick up.
Small resistors right at the plates may help (10 - 100 ohm and you may wrap a few turns of wire around them and make low q chokes as well)
Grid stopper resistors present? How about ceramic bypass caps from the filament pins right to chassis. (0.01uF will do nicely)
Don't dismiss the supply either as a possible cause, but I think it pretty unlikely - your plate chokes should provide a pretty high psrr.
www.kta-hifi.net
Old 3rd May 2007, 11:41 PM   #3
alexg's Avatar
Unfortunately, I do not have access to oscilloscope. Grid stopper is present (5K).
Yesterday afternoon, I was using the preamp for more than two hours and the buzz/hum was not present.
Since the buzz/hum was bugging me so much, I worked on the preamp last night. I replaced the grid wire with a shielded coaxial wire, the shielding grounded inside the preamp and the other end floating near the grid connection at the top of the tube. (I did this because everytime I touched the grid wires, I get serious hum). After replacing the wires, when I touch it no hum.
I also re-soldered all the ground connection (when it is buzzing/humming, when I touch the chassis, the buzz/hum disappears, might be ground loop problem).
I also took out the 470uf electrolytic on my PSU, I just left the 3 5uf+25uf motor run capacitors (according to PSUD simulation, the ripple just increased from 180uV to 1.1mV, which should not be significant). This opened the top and tightened the bass.
I have been using the preamp since last night, 10 hours and the buzz/hum has not come back yet. If I fixed the problem, the only thing that would bug me now is which of the things I did fixed it.
Old 4th May 2007, 12:25 AM   #4
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
I would speculate - bad solder. a common mistake is using the solder to fuse the parts together. a good practice is to hook the component leads to each other or to the terminal lugs.
the amps and preamps that we made, are dropped 2 feet above ground on a carpet and tested again. all of them still work and will survive DHL or FedEx even if one was physically twisted a bit (I don't know how these courier guys can do that) when it arrived in California.
I'd like to hear that preamp, when you're not busy let me know when I can drive to Laguna
Old 4th May 2007, 01:30 AM   #5
alexg's Avatar
Thanks Arnold.
I used to solder like you have described, but now I learned to mechanically couple the parts if possible and then solder.
I was using a very thick (around 2mm diameter) copper wire as my main ground point for star grounding. I think my 30w soldering iron cannot heat it up adequately for a good solder joint, so I borrowed our company's Weller soldering gun and it seemed to be perfect for soldering the ground wires.
My system is powered up now for almost 12 hours and the hum/buzz has not come back yet.
Thanks.
Old 8th May 2007, 07:10 AM   #6
Would you care to share your schematic?
BTW, I do have a handfull of these tubes which I would like to
build some preamps for my own use.
Old 8th May 2007, 11:35 PM   #7
alexg's Avatar
Here is the link to the designer's page, scroll to the bottom of the page for the circuit and psu schematic.
http://www.the-planet.org/linestage.html
Buzz in new amp... chrish Tubes / Valves 10 20th February 2008 04:06 AM
Carver PSC-60 Preamp - Buzz. AltheaToldMe Digital Source 0 27th January 2008 08:46 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
Buzz on preamp alexmoose Tubes / Valves 25 19th December 2006 08:40 PM
A-75 buzz Dave Varner Pass Labs 3 15th February 2002 01:30 PM
Page generated in 0.09417 seconds (84.36% PHP - 15.64% MySQL) with 10 queries
