diyAudio Sponsor
Old 2nd May 2007, 06:59 PM   #1
pchw is offline pchw  United States
Default Does anhone use those switching power supply for the heaters?
I was looking for some parts in MPJA and came across the power supply section. Something like this
http://mpja.com/productview.asp?product=16918+PS
cost less than 10 bucks and can easily provide the DC power supply for 4 6SN7's heaters (series and parallel wiring). These seem to be a handyway to offer VDC to the heaters of small tubes.
Did anyone use this kind of desktop power supply for such application?
Thanks,
- Fred -
Old 2nd May 2007, 07:03 PM   #2
I have heard before (however I have never tested myself) that using a swtich-mode power supply is too noisey to use for DC heaters. What I would do personally, would be to run that through a linear regulator, that would elimante the noise put in by the SWPS.
-Moose
Old 2nd May 2007, 09:17 PM   #3
JoshK is offline JoshK  United States
I think it might be interesting to get some cheap but substanitive surplus chokes and place them before and after the SMPS and shield the SMPS and see how it sounds. Try both CMC and series Choke.
Old 2nd May 2007, 09:23 PM   #4
nhuwar is offline nhuwar  United States
nhuwar's Avatar
I'm thinking about using Some higher end smps for a amp I'm building.
Although I dont know how they sound yet.
But I was always told it was easier to filter out higher frequencies then lower.
Nick
Old 3rd May 2007, 01:30 AM   #5
What about using one of these:
http://mpja.com/productview.asp?product=15654+PS
as following:
PS <=> 4700uF/25V <=> LM317 <=> o12.6VDC
0.01uF
ground.
Will that help reducing the noise?
- Fred -
Old 3rd May 2007, 04:05 AM   #6
tjl is offline tjl  Taiwan
Switching power supply for tube filament heating will be more convenience and also save space of linear power transformer,
At lower heater current voltage amplifier stage , I use LM317 linear regulator like PCHW mention about before, but LM317 need big heatsink for heat dissipation.
AT power amplifier stage, I prefer Switching power supply for the huge current of tube filaments.
As my experience: Switching power supply for tube filament will not inducing hum or noise, because its operating frequency is about 28KHz to 60KHz far away from audio frequency range.
12V 3.3A switching adaptor may be suit for 4 X 6SN7 tubes by series and parallel connection, but if add a 1000uf 12V capacitor on the output terminal will boost current and more stable for 12V voltage output.
TJL
Old 3rd May 2007, 12:57 PM   #7
Brian Beck's Avatar
I've used in-line laptop power supplies that look similar to the supplies in the MPJA links, but have output voltages in the 18 to 20 volt range. These were various Dell models. Then I've used linear regulators (in the LM317 family) to drop the voltage down to 12.6 volts and to filter out noise. You need passive filtering to remove all the switching noise since the LM317 isn't fast enough to keep up with 50KHz noise. I suggest adding a ferrite clamp onto the lead going from the in-line supply to the chassis, if the unit doesn't already have one (many do), as well as chokes and caps inside the chassis before the LM317.
If not well filtered, the switching noise, even if it is ultrasonic, can intermodulate with digital artifacts from CD players to make in-band tones. I think it's best to include linear regulators and to filter well with passive parts.
The advantage of the in-line laptop switchers is that they can be separated physically from the sensitive audio circuits. They tend to be very efficient, lightweight and cool-running.
Brian
Old 3rd May 2007, 02:23 PM   #8
What kind of choke is adequate for the job?
Thanks,
- Fred -
Old 3rd May 2007, 11:23 PM   #9
Thanks,
I would think a few turns around a ferrite ring used for noise suppression on computer ribbon cables will do the job.
Also, put a 100 nF. film cap. directly across the I/P pins of the linear regulator IC.
Finally, 2X 7812 fixed regulators will do nicely for 4X 6SN7 heaters. The 0.6 V. "error" is well within tolerance.
Eli D.
Old 4th May 2007, 03:51 PM   #10
I am building a PP 6c33c amp, which amounts to 6.3v @ 12-14a per channel of heater needed (if running both cathodes on each tube). Or one can wire for 12.6V @ 6-7a, still a lot of heater juice needed. I think I will look further into the SWPS option for at least powering the output stage heaters.
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
K6- Switching power supply microsim444 Power Supplies 3 17th January 2009 12:10 PM
Tube filaments (heaters) power supply matejS Tubes / Valves 5 12th July 2007 05:50 PM
Switching 12V power supply PCB soundNERD Power Supplies 35 27th April 2005 01:35 AM
Switching power supply Thomas B Pass Labs 15 9th December 2002 10:28 PM
Page generated in 0.10446 seconds (80.52% PHP - 19.48% MySQL) with 10 queries
