diyAudio Sponsor
Old 2nd May 2007, 07:10 PM   #1
cloud is offline cloud  United States
Default Se Opt
Does anyone know of a SE OTP that has a 2.5k pri and multi secondaries for headphone use ? Tap's 32 to 600 ohm
Old 2nd May 2007, 07:25 PM   #2
dsavitsk's Avatar
http://electra-print.com/lineoutput.php
http://www.ecp.cc/semha.html
http://www.sowter.co.uk/headphone.htm
http://www.ecpaudio.com
Old 2nd May 2007, 09:36 PM   #3
Tubes4e4's Avatar
Default Re: Se Opt
Hi cloud,
What would be the objective of such an arrangement? I mean, use standard SE OPT, disconnect speakers by switch, slab a suitable dummy load across the secondary (10 ohms for 8 ohms nominal sec, 4,7 ohms for 4 ohms nominal), then parallel whichever impedance headphone you want to that, be happy.
No?
Tom
If in doubt, just measure.
Old 2nd May 2007, 10:07 PM   #4
dsavitsk's Avatar
Default Re: Re: Se Opt
Originally posted by Tubes4e4
be happy.
No?
No, not quite. This steals quite a lot of power from the amp. This is not a problem if you use a standard driver tube -> power tube configuration, but with a dedicated OPT with the right tap, it opens up the possibility of a simple spud amp using a 5842/437a/6c45/6688/7788, etc. I happen to like this a lot, plus it is cheaper to build in that the power supply requirements are simpler, and even custom wound OPTs can be less expensive. And, it can make a pretty good line stage too. It is still heavy, expensive, and hot, but it is less heavy, expensive, and hot.
Old 3rd May 2007, 05:13 AM   #5
Tubes4e4's Avatar
Default Re: Re: Re: Se Opt
Hi dsavitsk,
Oh, I see what you mean, I didnīt consider such small tubes.
But if you scale that only slightly, say a spud using a single trioded D3a, EL83, EL84 or something, a std 10k:4/8 ohms xfrmr plus dummy load still would be viable.
Regards, Tom
Old 4th May 2007, 04:11 PM   #6
Default SE opt/line Trans
dsavitsk> Thank's after using your link's found what I need for under $30.00 us
Page generated in 0.08579 seconds (75.49% PHP - 24.51% MySQL) with 9 queries
Copyright Đ1999-2012 diyAudio
