Setting Pentode Screen Grid Voltage - diyAudio
Old 19th January 2003, 09:34 PM   #1
dshortt9's Avatar
Default Setting Pentode Screen Grid Voltage
I am designing a push-pull tube amp and trying to decide whether to set the screen grids at 300v. or at the plate voltage of 550. KT-90's for tubes so the screens would be 100 volts below the 650 volt max.
What are the tradeoffs as far as power, distortion, Rp, drive voltage, etc?
Old 20th January 2003, 12:22 AM   #2
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Default Re: Setting Pentode Screen Grid Voltage
No experience with beam tetrode output stages, but remember the current that these valves pass is completely dictated by the screen grid voltage - hence the flat curves: varying the anode voltage makes no difference.
If I were you I would try to obtain curves for various g2 voltages and select your operaitng points accordingly.
Your valves wil pass a lot more current with 550V on g2 - and you must also be careful not to exceed the maximum screen grid dissipation (Pg2)
7N7
Plug them in and light them up
Pentode cathode follower with regulated screen voltage? G Tubes / Valves 14 19th November 2013 12:01 AM
Pentode grid question... Brouilly Tubes / Valves 10 28th March 2009 08:02 PM
pentode with grid AND cathode tied to gnd? xdissent Tubes / Valves 5 28th December 2007 02:18 PM
Control grid Voltage / grid stoppers... jon_010101 Tubes / Valves 2 4th May 2006 02:59 AM
6V6 SE and Screen Grid Voltage zxx123 Tubes / Valves 5 2nd February 2005 06:36 PM
Copyright 1999-2017 diyAudio
