Old 1st February 2003, 11:24 PM   #61
diyAudio Senior Member
fdegrove's Avatar
Default PUB TALK.
Thought you was...
I meant to try reducing the value of the grid stoppers,
Doesn't really matter though...you catch my drift.
If you allow a litle tip:
Never make gridstoppers any larger than strictly necessary.
Ciao,
Frank
Old 1st February 2003, 11:40 PM   #62
slowmotion's Avatar
Since it is direct coupled you should be able
to take away the grid stoppers too, or....
- Jan -
Old 1st February 2003, 11:42 PM   #63
fdegrove's Avatar
Default NO.
Frank
Old 1st February 2003, 11:56 PM   #64
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Default Re: PUB TALK.
Originally posted by fdegrove
Thought you was...
Ciao,
Of course and this is particularly apposite in this case, where I am anxious to have as low a source resistance as possible. However, I once built a 6SN7 line stage with cathode followers. The 6SN7s had 470 ohm grid stoppers - a typical choice - but the stage was oscillating at about 2.5MHz!
On the 6528A I have used the minimum recommended by the makers (1k) which is pretty low for an output stage - even EL84 uses 4.7k as a rule.
However, I am going to try 470 ohms and watch the 'scope!
Incidentally, I am considering using a similar arrangement of driver stage in the 13E1 amplifier. Here though bias is about
-51V, so I shall have to wring some more swing out of it
7N7
Plug them in and light them up
Old 2nd February 2003, 12:03 AM   #65
fdegrove's Avatar
Default THE SHORT ANSWER.
Although this was voiced by me before...
Don't design oscillators, gridstoppers as any other series R will eat microdetail and as such will reduce dynamic resolution.
I think this should make sense?
\Frank,the unipivot.
Frank
Old 2nd February 2003, 12:12 AM   #66
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
I'm not clear on these gridstoppers.
What kind of oscillation are we talking about? Barkhausen (or however it's spelled)? If it is, there are other ways....
Cheers
Old 2nd February 2003, 12:15 AM   #67
fdegrove's Avatar
Default CRITTERS.
Mainly RFI osc.
The 6C45C is another matter,it tends to go into self osc.
Chin kampai,
Frank
Old 2nd February 2003, 12:26 AM   #68
7N7's Avatar
Default Re: THE SHORT ANSWER.
Design oscillators?
Perish the thort in the words of N. Molesworth.
I shall try to reduce the value of them for the reasons I gave above - and I shall be keeping a close eye on the 'scope.
When I've fixed the 13E1 amp I'll have a go and also try removing the grid leaks. I'll report my findings, gentlemen, for your perusal
7N7
File Type: gif smoking[1].gif (877 Bytes, 120 views)
Old 2nd February 2003, 12:37 AM   #69
fdegrove's Avatar
Default WRONG POST WRONG PLACE...
This should have gone into the 6C45 thread...blimey...reducing Rg won't hurt though.
Sorry,wrong channel...
Back to the bunker...
Frank
Page generated in 0.29281 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
