| diyAudio Sponsor | ||
I have some 5K 5W wirewound linear pots -- no idea why I have them anymore. I am building a guitar amp and was wondering if there is any reason not to use them for Rk on the output tube. The idea is that I can adjust for different tubes and different operating points without having to resolder and without reaching inside the chassis. Other than the issue that someone not familiar with the amp could cause damage, are there other reasons to avoid doing this?
http://www.ecpaudio.com |
#2 | |
If you intend to do lots of tube rolling, you're probably better off using fixed bias. |
#3 |
The lowish dissipation rating of the pot might also be an issue depending on how much of the element is actually in circuit.
www.kta-hifi.net |
| Wirewound resistors | Mywing | Parts | 5 | 24th February 2009 05:27 PM |
| wirewound vs standard pots | ThSpeakerDude88 | Tubes / Valves | 2 | 25th March 2008 04:41 AM |
| Wirewound Pot Law Fake with Wirewound Resistor | wrenchone | Solid State | 6 | 13th September 2007 06:45 AM |
| wirewound pot as volume control | patriz | Parts | 3 | 26th October 2006 11:07 AM |
| Wirewound cathode resistor | Klimon | Tubes / Valves | 12 | 30th August 2006 10:19 PM |
| Page generated in 0.06804 seconds (79.00% PHP - 21.00% MySQL) with 10 queries |
