| diyAudio Sponsor | ||
I want to build a KT88/90 tube amp with using TAMURA F-2011 Output Transformer. I need to drive my TAD 15" woofer TL-1602 directly. Where I can find the schematic? Thanks Gary |
#2 |
Hi Gary,
the KT88 needs a Raa between 4 kOhm and 9 kOhm in push-pull circuits, http://frank.pocnet.net/sheets/086/k/KT88.pdf the Tamura F-2011 has a Raa 3,5 kOhms. You can use the Tamura F-2012 (with 5 kOhm) or connect the KT88 in triode mode for good damping factor (output power 20...30 Watts). Regards Andreas |
| Looking for Mikael's KT88 Schematic | Toyman_PA | Tubes / Valves | 130 | 3rd January 2008 09:24 PM |
| KT88 amp schematic/parts list | kgrant67 | Tubes / Valves | 12 | 5th July 2007 09:16 AM |
| KT88 schematic | 22mannightstar | Tubes / Valves | 18 | 19th September 2006 05:54 AM |
| KT88 SE schematic wanted. | Hojvaelde | Tubes / Valves | 9 | 1st June 2005 03:49 PM |
| Page generated in 0.06287 seconds (69.07% PHP - 30.93% MySQL) with 10 queries |
