diyAudio Sponsor
Old 28th April 2007, 10:49 PM   #1
Default Seperate PSU Transformers? Filament Supplys?
Hi, what would give best performance?
1. One transformer, rectifier, capacitor, choke for driver tube. One transformer, rectifier, capacitor, choke for output tube.
vs.
2. One transformer, rectifier, capacitor, choke for output tube then another choke to bring the voltage down for the driver tube.
3. Is it a smart idea to wind a rectifier filament supply into the power transformer?
I guess what i want to know is, would it be better to have a bunch of transformers or just one that powers everything.
thanks
Old 29th April 2007, 12:22 AM   #2
SY's Avatar
On an absolute basis, lotsa transformers is a better otion than one with lots of windings. First, noise from rectification won't couple from one winding to another (especially from the HV to the heater). Second, the output stage supply will tend to sag under load, so keeping the driver HV separate will help LF stability and overload recovery.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 29th April 2007, 02:20 AM   #3
aerius is offline aerius  Canada
Given that I currently have 9 transformers on headphone amp...
Old 29th April 2007, 02:31 AM   #4
agent.5 is offline agent.5  United States
You cannot have too many transformers.
My current project have about 32 transformers and chokes per mono block, or 64 transformers total.
Old 29th April 2007, 02:38 AM   #5
leadbelly's Avatar
So, if I were to generalize (I guess the basis would be no PS regulation and no choke/CCS loading?), would the priority of adding extra PS iron be, in order of decreasing benefit:
1) Separate HV from filament windings.
2) Separate HV for input/driver from HV for output.
3) Separate filament for input/driver from filament for output.
Does regulation and/or choke/CCS loading impact this greatly?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 29th April 2007, 04:48 AM   #6
My word agent.5, what are you building?
Old 29th April 2007, 04:54 AM   #7
Tweeker is offline Tweeker  United States
A substation.
Be sure your foil hat has a good low impedance ground.
Old 29th April 2007, 05:33 AM   #8
250tl parafeed set --
2 stages with separate LCLC filtering for each stages
DC filament supplies with LCLC-CMC
choke loaded, input transformer, grid choke, separate bias supplies, etc, etc.
Old 29th April 2007, 07:51 AM   #9
Zoran is offline Zoran  Serbia
for the best tube design
is essential
1. each chanel separate CT heating transformer for the rectifier tube
2. each chanel separate CT heating transformer close to the output DHT tubes
3. good PS, DC symetric secondarys, transformer with lower DC res. of sec.
4. units has to be mounted in the chasis correctly.
5. chokes with gap, low dc res, good laminations, proper mounting away from TR.
All units has to be from good qty. laminates cores.
All units has to be with B less then 0.707 Tesla.
Old 2nd May 2007, 07:43 PM   #10
Hi, just got back,
Thanks Zoran.
agent.5 would you mind PMing/email me a schematic, i am interested in your design. I am working on a 304tlSE atm.
Weird old power transformers (filament, SS and tube) - $7 each! pjanda1 Swap Meet 6 29th March 2010 04:17 PM
Source for 2.5VCT 5A filament transformers dsavitsk Tubes / Valves 2 15th January 2009 08:39 PM
Plate and Filament Transformers dscrobe Tubes / Valves 1 21st August 2008 04:57 PM
Why should a gainclone sound worse with seperate transformers? Dr.H Chip Amps 16 21st August 2003 09:02 PM
seperate transformers Yoda Solid State 10 7th August 2001 08:08 AM
Page generated in 0.09804 seconds (77.15% PHP - 22.85% MySQL) with 10 queries
