diyAudio Sponsor
Old 26th April 2007, 07:46 PM   #1
bigdx is offline bigdx  United States
Default Herron phono
Hi
Can anybody help me with a Herron VTPH circuit diagram? I want to upgrade the coupling caps. I would like to avoid the couplers in the RIAA stage.
If no circuit diagram available, is there anybody out there that has done a Herron that can send me a photo?
Paul
Old 28th April 2007, 01:03 AM   #2
Hi Bigdx,
The diagram does not appear to be available - but I bet you also googled. What I did find were comments on rediculous "deviation" from RIAA like 0.2 dB, capacitors costing >$25 etc., ..... Which brings me, as an experienced EE, to ask why one wants to change? It is of course your money and property, but still, having read some of the comments ..... Respectfully hoping you are not under the influence of some of those.
Regards.
Old 28th April 2007, 04:43 PM   #3
Hi Johan
I am thinking the sonic qualities of teflon film caps like the TFTF V-Cap is far superior than those of a polypropylene. I have upgraded a number of amps and generally liked the result. I have replaced one stereo pair in the Herron already, and the results are (to my ear) nothing less than stunning.
I want to leave the caps in a RIAA alone – I believe Keith matches them by hand to get the equalization spot on. A circuit diagram would have been quite helpful in identifying the coupling caps that are situated in the RIAA stage.
Paul
Old 28th April 2007, 09:35 PM   #4
diyAudio Senior Member
fdegrove's Avatar
You could unsolder them then measure them with a capacitance meter if there are no value markings present.
Frank
Which Phono Pre??? Freecrowder Tubes / Valves 1 5th February 2009 09:45 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Phono transformer VS Active phono pre ckwong99 Analogue Source 0 2nd November 2005 04:35 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.07709 seconds (73.11% PHP - 26.89% MySQL) with 10 queries
