| diyAudio Sponsor | ||
?Hey everyone first post.
I just have a quick question about the topic. I've made myself a 12ax7 preamp following hoffmans design, and i plan to make any decent poweramp, mosfet, bjt, gainclone. Ummmm so no clue about tube outputs but i assume the voltage is very high from the 12ax7 ( i'm giveing them 224V B+ is that ok?) so when it leavs the preamp and hits the poweramp will these voltage cause any upsets on my behalf |
#2 |
In this forum all think that no exist any decent SS poweramp.
.... Build one PushPull EL34, 6L6, 5881, EL84 it is decent amp !!!!!! |
#3 |
a yes but i plan to throw in 100 watt power amp. which isn't withing my $$$$ range for all tube.
ANSWER QUESTION >_< lawl!!! not asking whats best just asking if a tube preamp output is fine with a SS poweramp input |
#4 |
Yes, it is fine, don't worry (don't forget the coupling cap though)
"There's something organic about a happy cloud of electrons" - Neutron Bob |
#5 |
It depends on input impedance of your SS output stage: how high it is, how it depends on a frequency, and how linear, that is also very significant.
I got very-very good results using triode strapped 12L6GC driving 4 transistors.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 | |
#7 |
cheers all.
#8 |
I see you are in Melbourne which means that you have one of the best SS Amps anywhere available just down the street.
Have a chat to Hugh Dean. http://www.aksaonline.com/ I have one of his LIFEFORCE 55 amps and one of his older AKSA 55 Nivarna Plus Amps. I use these as reference amps against which I judge the valve amps I design and build. The LIFEFORCE 55 is stunningly detailed and articulate with effortless presentation across the entire frequency range. The AKSA 55 has a bit of that valve like sound, warm and rich. I run one of his GK-1 tube buffered preamps all the time, regardless of what power amp I have hooked up on any given day. Cheers, Ian |
#9 |
haha my boss ( head of flc microdesign ,coolon) says a well designed MOSFET can do anything a tube can.
Also umm dave ulbrick from ulbrick Sound builds his amps bout 2 k from my house lawl. |
| Tube Preamp Module and Power Supply PCB's | Geek | Swap Meet | 47 | 31st January 2009 08:48 AM |
| looking for hv power supply kit for car tube preamp | tomat | Parts | 6 | 7th December 2008 02:48 AM |
| Balanced tube preamp for class D power amps. | jane | Tubes / Valves | 5 | 13th December 2006 07:41 AM |
| WTB:power supply for tube preamp | dariusku | Swap Meet | 0 | 18th September 2006 06:04 PM |
| power supply for tube preamp | rafafredd | Tubes / Valves | 11 | 15th November 2002 03:32 PM |
| Page generated in 0.08926 seconds (80.54% PHP - 19.46% MySQL) with 10 queries |
