diyAudio Sponsor
Old 25th April 2007, 12:05 PM   #1
Tobruk is offline Tobruk  Italy
Default Ecc81
I am looking for a schematic about an ECC81 input tube direct coupled to an ECC82 or 6SN7 cathodyne phase splitter for my hombrew push-pull EL 84 amplifier.I thank you in advance.
regards
Franco.-
Old 25th April 2007, 12:23 PM   #2
SY's Avatar
You only need to swing 11V or so to drive an EL84 to clipping- why use a phase-splitter with gain and add some extra rolloffs in the bargain? You'd do better, I think, with a voltage amp direct coupled to a split-load. The ECC81 works very, very well in that service.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th April 2007, 12:29 PM   #3
I think an ECC82 Cathodyne phase splitter has not gain(or very low)
ciao
Old 25th April 2007, 12:34 PM   #4
SY's Avatar
Maybe I misunderstand the term "cathodyne." If it's the same thing as a split-load, then do a forum search for the Red Light District amplifier. I used an ECC81 for both the input voltage amp and the split-load- ECC82 is a much inferior tube for that service.
Old 25th April 2007, 12:38 PM   #5
Merlinb is offline Merlinb  United Kingdom
This is pretty much what you asked for: http://www.freewebs.com/valvewizard/cathodyne.html
Old 25th April 2007, 01:11 PM   #6
As Sy said, that's often referred to as a "split-load" phase inverter. And I second his recommendation for the 12AT7, especially if you are using a P-P output stage. A single 12AT7 will provide plenty of gain in the right configuration.
You might look at the "El-Cheapo" front end (on the Decware forum). Of course, Sy's suggestion is good too (I'm sure!), I'm just not nearly as familiar with it.
"El-Cheapo" does not use a cathodyne/split-load PI, but you still might find it very appealing.
Old 25th April 2007, 02:47 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Actually, it has more gain...
Although a concertina/cathodyne/split load phase splitter doesn't have gain to an individual output, it has a differential gain of two, so in combination with a typical common cathode input stage it has a gain double that of a phase splitter based on a differential pair.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
7 pin ECC81. Cassiel Tubes / Valves 9 16th February 2009 02:00 PM
Ecc81 12at7 316a Swap Meet 0 30th May 2008 11:51 AM
Test of ECC81 to 83 Hojvaelde Tubes / Valves 1 11th January 2008 01:02 PM
ecc81 gianis Swap Meet 0 12th June 2006 08:44 PM
ECC81 or 83 or 85 or 88 ??? Bernhard Tubes / Valves 1 26th December 2003 03:57 PM
Page generated in 0.09300 seconds (80.64% PHP - 19.36% MySQL) with 10 queries
