I just finally bought my output xfmr's for my push pull amp. I got the amorphous core's the lundahl ll9202am and am kind of worried if I jumped the gun or not.
Are the amorphous core as good as they say they are? Thanks Nick |
#2 |
Law of diminishing returns comes into play here, but your already in hundreds dollars for vanilla Lundahls...
The OPT is the heart of your amp.
Be sure your foil hat has a good low impedance ground. |
#3 |
Some like amorphous cores, some like vintage EI. It all sounds great, it just has different character. Amorphous core trannys give very nice high ranges.
#4 |
I was just worried I fell victim of marketing.
Nick |
#5 |
Less hysteresis and eddy current losses for amorphous core, these losses go up with frequency.
#6 |
Well I think that it was a better buy in my case sense I'm using a fairly impedence tube.
Nick |
#7 |
I believe amorphous iron core OPT's are good. Why don't you build the amp with it and try it out yourself.
If you don't like it, sell them on Ebay. Johnny |
#8 |
According to the Tamura transformer catalog. http://www.tamura-ss.co.jp/catalog/pdf/C-1005-13.pdf
F7001 is Permalloy cores and F5002 is Amorphous core. They are both 3K, 8W. Check the selling price in here. http://www.hino-audio.co.jp/03/tamura.html F7001 is 38120 yen. F5002 is 58260 yen. Can the price tell you the different? Also the frequency response, F7001 is 15-60K. It is pretty good. F5002 is 10-100K. F5002 is a well known the best transformer for 300B. So, I think Amorphour cores is better. My main concern is lundahl can handle this new material good or not. |
#9 |
#10 |
slightly different application - but my RAKK DAC uses a Lundahl LL1674 Amorphous line transformer - I've been very pleased with the sound.
| Plate choke material, why to use amorphous core? | noyan | Tubes / Valves | 5 | 7th July 2008 12:25 PM |
| Amorphous core power trannies for SS amps | rick57 | Solid State | 11 | 16th April 2006 12:47 AM |
| Amorphous core transformers only work above 20KHz? | edonion | Tubes / Valves | 12 | 23rd November 2004 11:30 PM |
| Solen Air core inductors, Hammond Iron core. | gnomus | Swap Meet | 0 | 30th July 2004 01:28 AM |
