diyAudio Sponsor
Old 24th April 2007, 05:35 PM   #1
Katapum is offline Katapum  Europe
Default Roll off frequency.
Hi all,
I´d like to find Jadis roll off frequency.
I think main formula is f=1/(2*pi*C*R). What are R and C values or what to do to find them?
I appreciate your help.
Katapum
Old 24th April 2007, 06:44 PM   #2
Tweeker is offline Tweeker  United States
R is in ohms, C is in Farads. To convert microfarads (uF) to farads, divide by 1 million.
This page is handy for determining the cutoff (-3dB) of an RC circuit.
This wont necessarily give you the amps actual limits, the OPT comes into play here too.
Be sure your foil hat has a good low impedance ground.
Old 24th April 2007, 07:02 PM   #3
HF rolloff will be determined by OPT or whenever the pair of 12AX7 sharing .8ma runs out of steam trying to drive 3 6550s in UL. I wouldnt expect it to be very high.
Old 24th April 2007, 07:28 PM   #4
For now I´m only concern about two ½ 12AX7 and 3 6550. So how can I exactly find C and R?
Old 24th April 2007, 07:35 PM   #5
The dominant roll off will be .47uF and 474k.
474k is a very high grid leak for what appear to be fixed bias 6550s.
Old 24th April 2007, 07:40 PM   #6
And Miller capacitance doesn’t play any roll?
Old 24th April 2007, 07:57 PM   #7
The .47uF and 477k is for LF roll off. Miller capacitance enters into HF and is much more complicated to calculate. It is often worse than it appears as the 12AX7s must supply the current to charge this capacitance, the 12AX7s output impedance is not the only factor. Calculating Miller capacitance for UL op is involved.
Designing Common-Cathode Triode Amplifiers.
Old 24th April 2007, 08:05 PM   #8
From another thread:
Posted by fdegrove
One caveat, the amp is seriously limited in high frequency response by its driver stage, it's starts to roll off gently from ~ 16KHz.
So how can I find 16kHz value?
Old 24th April 2007, 09:49 PM   #9
PCC88 is offline PCC88  United Kingdom
This page details the effects and calcs for Miller Effect
http://www.aikenamps.com/MillerCapacitance.html
the northern seas are cold, but they're our own.
Highs roll off wicked1 Tubes / Valves 3 5th April 2008 10:42 PM
Roll off power amp low end? audiobomber Solid State 3 3rd December 2006 07:17 PM
best amp for rock n roll sub_arctor Tubes / Valves 19 19th October 2006 11:44 PM
H-Frame High Frequency roll-off? DIY_newbie Multi-Way 7 13th September 2005 04:06 AM
Page generated in 0.08857 seconds (81.21% PHP - 18.79% MySQL) with 11 queries
