diyAudio Sponsor
Old 24th April 2007, 01:32 AM   #1
jarthel is offline jarthel  Australia
Default how to set output current on G Pimm's CCS circuit?
Here's the circuit: http://img340.imageshack.us/my.php?i...biasccsfs9.gif
I have a feeling it is measured across R1. Is this right
Also, do I need to have a load? I am thinking of just the transformer -> rectifier -> choke -> cap -> CCS circuit. nothing else after it.
Do I need to connect the negative terminal of CCS circuit anywhere if it's okay if there no load?
thank you.
Old 24th April 2007, 04:54 AM   #2
kopite is offline kopite  New Zealand
The voltage across r1 is approx 14 volts. so using ohms law you can calculate the resisitir for r1. If you need to drawer 20ma you will use a 680 ohm resistor. Fine tune the current setting with the pot.
Old 24th April 2007, 05:08 AM   #3
Jarthel,
You have mail.
Looney
shunt regulator using VR tubes (with ccs like g pimm) and circuit load jarthel Tubes / Valves 2 23rd April 2007 03:33 PM
how to set current in G Pimm's latest self-biasing CCS circuit? jarthel Tubes / Valves 0 31st October 2006 11:36 PM
gary pimm's latest self-biasing CCS circuit jarthel Tubes / Valves 13 6th October 2006 04:16 AM
Inrush Current Limiting Circuit haldor Parts 22 8th October 2004 03:06 PM
Newly CCS circuit from Pimm mrstone Tubes / Valves 0 16th February 2004 09:04 AM
Page generated in 0.06087 seconds (74.45% PHP - 25.55% MySQL) with 10 queries
