diyAudio Sponsor
Old 22nd April 2007, 05:16 PM   #1
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Default Affordable, but good attenuators?
Anyone know of any good stereo attenuators? I don't really want to shell out over $100 for a gold point and have been using cheapies for now. However, the gang tolerances between the two sides are significant.
Old 22nd April 2007, 05:49 PM   #2
Hi
No personal experience, but you could look at www.tubecad.com, for Broskie's stepped attenuator, including balance
Erik
Old 22nd April 2007, 05:51 PM   #3
SY's Avatar
Personal experience. Broskie's attenuators are a bargain, but the ergonomics are a bit odd. They'd be my first choice in a limited-money situation.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 22nd April 2007, 06:01 PM   #4
zobsky is offline zobsky  India
zobsky's Avatar
peter daniel had a thread way back on affordable + good attenuators for the gainclone.
"Any fool can know. The point is to understand" - Albert Einstein
Old 22nd April 2007, 06:07 PM   #5
Klimon is offline Klimon  Belgium
there's a hongkong resident selling kits on ebay for under 50%; ladder type, 23pos, dale rn55 IIRC resistors... Looks hard to beat.
Simon
Old 22nd April 2007, 06:57 PM   #6
PECO brand hot molded Carbon controls are an EXCELLENT value. You get milspec construction and warm sound. Several guys I respect prefer PECO Carbon to stepped and you save a few bucks too boot.
DigiKey is the North American distributor for PECO.
Eli D.
Old 22nd April 2007, 07:03 PM   #7
dsavitsk's Avatar
I've had good luck with these too. The only down side is that they don't feel smooth when you turn them -- only an issue if you have a resonant chassis and a microphonic tube. Part number for a 50K at Digikey is KKA5031S28-ND
http://www.ecpaudio.com
Old 22nd April 2007, 09:57 PM   #8
I've just implemented a broskie stepped pot. Bought it 2ndhand, assembled but never used for $30.
I would echo SYs point, have to say its very neutral but ergonomics are a bit odd. Other point to note is that they way its made up of 3 pots (center is master volume and then 2 fine controls for L and R) you will drill 3 holes for the attenuator. However if you do ever decide to replace it with a single pot then you have 2 extra holes to fill.
Having said all that I seem to have ended up just using the center swtich on mine and rarely change the 2 other ones. Volume jumps a bit, but doesn't bother me.
I should say that this is in a passive pre built with a darwin source selector. I can see no sonic difference with/without the whole passive pre which to my mind means its totally neutral.
Fran
Old 23rd April 2007, 01:57 AM   #9
zobsky's Avatar
found the link, ... he prefered the PECO part too, but i never bothered to follow th thread to its end.
So I did try all those different potentiometers
Old 23rd April 2007, 02:31 AM   #10
rdf is offline rdf  Canada
rdf's Avatar
A bit out there and not stereo, but 10k, 10-turn wirewounds have done duty in my passive for the past 15 years flawlessly. Ergonomically better for high sensitivity amps requiring fewer 360 rotations. Optional vernier dials makes balancing a pip, great for neurotics desiring repeatable 1/1000 accuracy!
Where can I find good & affordable silver-plated OFC copper wires? Mrpong Parts 17 4th December 2011 09:51 AM
Looking for a good source for attenuators jduffy Tubes / Valves 4 18th January 2007 04:11 AM
WTB: A few good volume pots/cheapie attenuators. Spasticteapot Swap Meet 0 30th November 2006 04:45 AM
Affordable, good and *available* full range drivers? falcott Full Range 51 11th September 2004 07:32 PM
Looking for affordable, good sounding, balanced interconnect cables Peter Daniel Solid State 11 19th June 2004 06:15 PM
Page generated in 0.10914 seconds (81.93% PHP - 18.07% MySQL) with 10 queries
