mounting an EL34 upside-down
Old 22nd April 2007, 02:30 PM   #1
jarthel is offline jarthel  Australia
Default mounting an EL34 upside-down
as I need to conduct testing/measurements, I need to turn over the top of the chassis so I can get access to the pins/circuit. on top of the chassis are 2 tubes: 5AS4 and EL34. I have looked at the RCA 5AS4 datasheet and it says I can mount it upside down.
I've looked at Philip's and Mullard's datasheet for EL34 and I cannot find any mounting info.
any ideas?
thanks for the help
Old 22nd April 2007, 02:41 PM   #2
Tweeker is offline Tweeker  United States
Oodles of musical instrument heads have them mounted upside down, since forever.
Be sure your foil hat has a good low impedance ground.
Old 22nd April 2007, 04:32 PM   #3
thank you
mounting an EL34 upside-downHide this!Advertise here!
mounting tubes upside-down Mr. Triatic Tubes / Valves 18 9th August 2004 05:44 AM
Upside down port error!!! gchrist Multi-Way 5 21st August 2003 05:08 PM
The world turned upside down SY Tubes / Valves 7 10th August 2003 09:32 PM
Upside down speakers ashok Multi-Way 2 8th October 2002 11:06 AM
