diyAudio Sponsor
Old 21st April 2007, 06:23 PM   #1
Default Tube designs: 45 driving 45/2a3/300b?
Hi everyone,
I've been thinking of going all out and building a super expensive low power (SET perhaps?) tube amp with 45 tubes in driver position, powering 45, 2a3, or 300b. I've seen some designs with the 45 as output tubes, but I haven't found one with it in driver position. Does anyone have any ideas?
Cheers and thanks!
Old 21st April 2007, 07:33 PM   #2
45s are scarce and expensive. Also, there is the issue of controlling residual hum levels. Check out the curves for triode wired 6V6s. They give away NOTHING in the linearity dept. to the revered 6SN7. Use a triode strapped 6V6 to drive the DHT "final".
BTW, the 6AQ5 is essentially a 6V6 in a 7 pin mini bottle. It would kick butt as your driver.
Eli D.
Old 21st April 2007, 08:40 PM   #3
JoshK is offline JoshK  United States
Lynn Olson's Karna uses the 45 as a driver. Tubelab's 845 amps use the 45 as a driver.
Old 23rd April 2007, 12:59 AM   #4
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
They are worth it!
Old 23rd April 2007, 07:59 PM   #5
Send a message via MSN to audiodesign
look this my new 845 simple amp.
http://www.audiodesignguide.com/New845/New845.html
300B driving 845 otto88 Tubes / Valves 4 7th June 2009 08:47 AM
driving 845 push-pull with a signal from a 300B SE stage Antonio Tucci Tubes / Valves 1 20th February 2007 09:04 PM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 07:47 AM
What are the requirements for driving a 300B? G Tubes / Valves 26 3rd June 2004 05:18 PM
Need advice driving a tube Bernhard Pass Labs 8 7th July 2003 07:17 PM
Page generated in 0.09669 seconds (76.07% PHP - 23.93% MySQL) with 10 queries
