diyAudio Sponsor
Old 19th April 2007, 03:34 AM   #1
jarthel is offline jarthel  Australia
Default tv damper diodes
how to pick?
why 6ax4 over a 6au4? or why used that russian one?
any criteria? assuming current/voltage requirements are within specs of all diodes.
Old 19th April 2007, 03:41 AM   #2
56oval is offline 56oval  Australia
I,m looking at using tv diodes ,they all vary .
I found the 6CJ3 or 6CH3 are the ones to use large numbers a hard to get in the same value because there electrical values differ .
damper diodes .... sunrise Tubes / Valves 2 5th November 2008 10:05 PM
TV Damper Diodes Jack Thomas Tubes / Valves 8 10th September 2007 04:23 PM
TV Damper Diodes CarlyBoy Tubes / Valves 5 19th November 2006 09:20 PM
Damper Diodes hacknet Tubes / Valves 5 5th May 2004 08:35 AM
Page generated in 0.04715 seconds (79.06% PHP - 20.94% MySQL) with 10 queries
