| diyAudio Sponsor | ||
็Hi
I'm looking for some 6H30 preamp schematics by doing search on Google. Here is what I found:- http://digilander.libero.it/paeng/a_...ine_preamp.htm http://digilander.libero.it/paeng/hi...ubes_part3.htm Has anyone tried it? How good is it? Are there other interesting 6H30-based preamp schematics? Thanks! |
#2 |
Check also the 6H6 Thread which is a very similar tube. There are a few schematics in that thread.
It would be 6N6P in the latin alphabet.
Take the Speaker Voltage Test! |
#3 |
#4 |
Gentlemen;
it is called 6N30Pi
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 |
I think both ways of writing (kyrillic and latin) are applicable worldwide nowadays...no correction needed.
EDIT: @mrpong: you may want to include the aikido schematic which CAN be built as lineamplifier with 6H30...lots of threads in here. |
#6 | |
No, it is misleading. You can't write Cyrillic Pi using Latin letters, probably 6H30II will look similar, but not exactly. Cyrillic letter looking like H means X, i.e. double diode. 6N30P is a double triode. And yes, you may find lot of schematics in the Net, but 6N30P is a tube for computer usage, so it's linearity and repetitiveness of parameters is not good for audio applications if to compare to other tubes, though it is popular and overpriced. The same can be said about 6S33S (looks like 6C33C) that was developed for power supplies, without a linearity in mind. Sorry for a bitter truth, but this information I believe can save money and time...
#7 | |
#8 |
behind the valve,s are
Line OutPut Transformers made by BlackArt in Australia Model 6K600:20.6 the output trans are made for the 6H30pi . Its BlackArts circuit so I would have to get premisssion to post it. |
#9 | |
http://www.tubecad.com/2004/blog0011.htm |
#10 | ||
| Preamp design schematics done | Skywalker83 | Instruments and Amps | 6 | 1st January 2009 04:53 PM |
| New preamp schematics | andrei | Tubes / Valves | 24 | 24th October 2008 12:20 AM |
| Need helping in Grounded Grid preamp using 6H6P 6H30P | bitinhvi | Tubes / Valves | 1 | 28th July 2007 06:58 PM |
| 6H30P based cathode-follower schema kindly requested | beppe61 | Tubes / Valves | 11 | 10th October 2005 02:35 PM |
| ecc preamp schematics please!!! | kianbach | Tubes / Valves | 1 | 7th May 2005 12:31 AM |
| Page generated in 0.10964 seconds (80.29% PHP - 19.71% MySQL) with 10 queries |
