diyAudio Sponsor
Old 16th April 2007, 05:44 PM   #1
jeapel is offline jeapel  Canada
Default why not 10k pot
hi
standard input pot is 100k or 50k but for the best result
with miller input cap
cd output 2 v / 10k= only 200uA load current
to give better fc -3db or i m missing something
thanks
Old 16th April 2007, 09:13 PM   #2
analog_sa's Avatar
Where is the pot? If at the input of the power amp the high value is there to accomodate old fashioned tube sources. A lot of tube preamps don't feel comfortable driving less than 50k.
Old 16th April 2007, 10:27 PM   #3
it s a tube preamp with pot directly to input before first 6sn7
gain=20 Cin+Cmiller~=86pF and output feed directly a
aleph 3 power amp
Page generated in 0.05630 seconds (74.66% PHP - 25.34% MySQL) with 9 queries
