Low vs High aka Series vs Parallel Filaments
Old 15th April 2007, 06:25 AM   #1
ak_47_boy is offline ak_47_boy  Canada
Default Low vs High aka Series vs Parallel Filaments
I am designing with a tube that has two 6.3V filaments. 12.6V vs 6.3V. What way should i go for best sound? What way is easiest?
thanks
Old 15th April 2007, 06:37 AM   #2
Tweeker is offline Tweeker  United States
Easiest depends on your filament supply. Lower currents induce currents into other circuits less.
Be sure your foil hat has a good low impedance ground.
Old 15th April 2007, 07:11 AM   #3
andrew_whitham is offline andrew_whitham  United Kingdom
andrew_whitham's Avatar
Hey there,
AC, DC or regulated?
12.6v makes the DC / regulating easier, - less current smaller components and so on.
Individually controlling 6.3v to each triode section sometimes helps with the matching between sections. Although I've never tested across an individual tube, I've seen a couple of 6.3v tubes in series (oh dear) where the second tube had only 5v on the heater pins...
BTW AK_47_boy. is this a power output tube or a pre-amp tube? how much current are we talking about here?
Andy
Old 15th April 2007, 07:53 AM   #4
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
You are lucky Andy, I've never seen that.
If the tube have separate filaments like 12AX7 there is no harm in connecting them in series, the tube is designed for such operations. I even use 6P3S-E tubes with filaments in series to power them from the same 12.6V source I use to rectify and regulate for small tubes. However, I have to use similar tubes, for example don't mix 6P3S-E and Chinese 6L6GC, but it is not a problem since anyway it is better to use matched tubes in the output stage.
The Devil is not so terrible as his math model is!
Old 15th April 2007, 08:34 AM   #5
Default )
Yeah I felt lucky too
Maybe I wasn't clear these were separate tubes - both JAN 6922's for the record. Not a combined tube,
However it got me (at first) thinking that the same problem might exist in a shared envelope. I know it shouldnt, but. On the tubes I've seen in bits they have 2 separate heaters linked by a bar under the mica. I guess that the 2 heaters are not necesarilly forced to be *identical* but they must be from roughly the same production run - close enough then?
Incidentally wavebourn, do you current or voltage regulate? current regulation of multiple tubes in series seems to be logical, although I've never tried it. (and I cant find that reference either!)
Cheers
Andy
Old 15th April 2007, 05:50 PM   #6
Its a directly heated thoriated filament output tube.
Old 15th April 2007, 11:48 PM   #7
Wavebourn's Avatar
Default Re: )
Factory rejects out of specs?
Andy
I regulate a voltage, but limit a current on the level just above needed for hot tubes though they start slower.
Old 16th April 2007, 01:16 AM   #8
Dave Cigna is offline Dave Cigna  United States
Dave Cigna's Avatar
Then I would definitely parallel them. With DC heating a series connection would put the two 'cathodes' 6.3V apart making it difficult or impossible to get them both to bias up the same.
With AC heating, a series connection makes it impossible to null heater supply hum. The best you could do is to ground the center connection between the two filaments. In that case, one end of each would be grounded (obviously) while the other end would be swinging 6.3V. That's the same as applying a 3.15V 60Hz signal between grid and cathode. It makes the amp hum.
What you want to do is create a virtual ground at the center point of each filament so that either end is swinging 3.15V and the two ends are out of phase. The grid to cathode voltage (averaged across the entire filament) remains fairly constant thus reducing hum. This is typically accomplished by grounding the CT of the filament transformer, or putting a pair of equal resistors across the filament with the center connection grounded, or using a hum pot with the wiper grounded.
-- Dave
January 20, 2009: Bush's last day
Old 22nd April 2007, 10:54 AM   #9
Default Re: Re: )
I wouldnt like to comment they were fitted as 'standard' in a particularly well known brand... Probably just my dumb luck
I never got a pair with "matched" heaters though in the end I gave up when I got close enough
Andy
Old 22nd April 2007, 12:01 PM   #10
5687 is an example of a tube with heaters allowing series or parallel heater connections.
Low vs High aka Series vs Parallel FilamentsHide this!Advertise here!
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 20th February 2014 12:16 AM
series or parallel? medicman Tubes / Valves 5 22nd January 2009 05:42 PM
Series connection of filaments leadbelly Tubes / Valves 24 15th August 2007 01:12 PM
Tube filaments in series? Klimon Tubes / Valves 7 7th April 2007 10:16 AM
Copyright ©1999-2017 diyAudio
