#22 | |
diyAudio Moderator Emeritus
My instincts...
.My guts... .Quote:
Well it's a long way off (September). I missed it last year, so I'll probably try to go this year. Cheers Bas, |
#23 | |
diyAudio Senior Member
If you don't have any hum while using AC then why not? On DHT triodes using DC will definetely change the sound,I mentioned this before it also changes the plotted curves. IMO,the main advantage of using AC is the preservation of the heater to cathode relationship. Adding sand devices in the heater circuit will often have a sonic impact,improving on S/N and bass performance,hence to many ears make them sound more sandlike. Take your pick,
Frank |
| TIP50 + LM317 High Voltage Regulator | bee696 | Tubes / Valves | 11 | 17th January 2010 04:23 PM |
| LM317 Regulator Problem | Bryan | Tubes / Valves | 12 | 2nd December 2005 07:37 PM |
| current boost lm317 prob. | deepanger | Solid State | 15 | 7th October 2004 06:52 AM |
| Can LM317 be used as GC PS regulator? | goering | Chip Amps | 5 | 15th September 2004 08:39 PM |
| current boosted lm317.. | deepanger | Solid State | 6 | 11th September 2003 01:30 PM |
