LM317 current regulator
Old 17th January 2003, 12:32 PM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Hi Bas,
Use Duncan's PSU program to simulate.
It'll depend on your smoothing to a great extent.
I use DC for the drivers through CRC smoothing, with a resistor in the top and bottom rails. This gets rid of the slow common mode crap. The fast stuff is trapped by a common mode choke.
The 845's use AC at present, and the hum is only just good enough. I'm considering DC.
I considered HF heating, but decided against it because of possible IMD.
Old 17th January 2003, 03:19 PM   #12
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default WHY WORRY?
Hi Bas,
Why would you want to do this?
Do your DHT flash up at switch on?
Frank
Old 17th January 2003, 03:30 PM   #13
Joel is offline Joel  United States
Joel's Avatar
I agree with Frank, Bas. What possible benefit is there to current limiting filaments?
I'm building a voltage regulated supply for my DHT filaments this weekend, but it's for lowering hum mostly - as far as how much current they draw - who cares?
Old 17th January 2003, 03:34 PM   #14
fdegrove's Avatar
Default CURRENT.
Well,you should care of course.
But as long as the PSU can supply the current they require I don't see any advantage.
Just don't starve them on current.
All current (no pun) tubes have controlled heater warm up built right in anyway.
Frank
Old 17th January 2003, 03:52 PM   #15
Bas Horneman is offline Bas Horneman  Netherlands
Bas Horneman's Avatar
Why am I doing this...well...because....i can!!
Just kidding.
Know the old discussion about AC/DC on the filaments? Sure you do.
Apparently one of the better sounding DC solutions is current regulation. (Jeez where have you guys been the last couple of years) ;-)
Doede Douma of www.dddac.de fame has made a couple of boards..so he must be thinking of doing the same thing. He has these boards where you have voltage reg and current reg.
(Actually just checked a new page (for the first time) of his out where he says a couple of things about it and actually has the formula that I originally posted for) Duh..RTFM BAS
I want to go a step further and do some filtering after that... as John is doing...ie resistors for the slow junk and common mode chokes for the fast nasties.
Thereby creating a sort of deluxe DC filament supply hopefully able to compete with AC.
What do you guys think...Personally I am baffled by the fact that most people agree AC on filaments sounds better...and the EE type DIY'ers have not designed some ultra good sounding DC supply, with boards and the works. There must be a good market for that.
Bas
Old 17th January 2003, 04:09 PM   #16
dhaen's Avatar
Baz,
My gut instict is that regulation (of either type) is only useful for controlling emission. And that the variations in my mains supply: about 0 to -3%, do not warrant it.
Indeed, if I were to incorporate regulation, I would need to include further noise filtering, as regualtors can be "noisy buggers".
Regarding current vs. voltage regulation:
Most of the valves we use are specified for either:
1) Fixed voltage source
or,
2) Fixed current source
The fixed current source types are mainly TV and AC/DC radio types.
I am unconvinced that running a valve contary to it's specification will reap benefits.
So there..
The few "dual specified" types that come to mind are the ECC8X series, but even they have different pins used for each.
Having just read this through, it sounds really bitchy; it's not meant that way.
Old 17th January 2003, 04:13 PM   #17
Joel's Avatar
This is merely fashionable at the moment. In 5 years everybody and his brother will swear by DC.
What I'm baffled by is just how many people assume everybody in 1930 was retarded.
Old 17th January 2003, 04:15 PM   #18
You bitch you! I'll bitch slap you right off this forum. ;-)
Ok enough joking..
Hi John,
John being in EE I can see why you would say that..
My standard response is if it sounds good it is good...!!!
Old 17th January 2003, 04:22 PM   #19
dhaen's Avatar
Bas,
If dogs could talk..
Old 17th January 2003, 05:04 PM   #20
It's a dog eats dog world..
LM317 current regulatorHide this!Advertise here!
TIP50 + LM317 High Voltage Regulator bee696 Tubes / Valves 11 17th January 2010 04:23 PM
LM317 Regulator Problem Bryan Tubes / Valves 12 2nd December 2005 07:37 PM
current boost lm317 prob. deepanger Solid State 15 7th October 2004 06:52 AM
Can LM317 be used as GC PS regulator? goering Chip Amps 5 15th September 2004 08:39 PM
current boosted lm317.. deepanger Solid State 6 11th September 2003 01:30 PM
