A thought on Cathode feedback
Old 14th April 2007, 03:20 AM   #1
alexmoose is offline alexmoose  United States
alexmoose's Avatar
Default A thought on Cathode feedback
Hello everybody!
The Michigan Technological University Audio Engineering Soceity is having an equipment listening session this sunday, and I have agreed to bring my EL34 SET amp along. I want the amp sounding its absolute best, so I am tweaking it.
The first thing I did was take measurements to make sure everything was on spec (it is ).
After measuring everything, I took off the Cathode Feedback, The amp's Midrange came to life, however the bass died a painfull death. So this leads me to thinking. What if I use One capacitor to bypass all of the high frequencies to gound, and another Capacitor to allow all the low frequencies to to become part of a cathode feeback loop. I even came up with a schematic in eagle to show everyone what I am thinking about, now, as you see this, you must understand that this schematic only shows the bias circuitry, not the entire output stage
Will this work? Does it look like a good idea? I know I will have to be carfull picking capacitor values, and The CK will have to be far smaller than CF (see Schematic).
my other questions about this are dependent on the fact that it will work, How do I find the impedances to base the cap values off of?
Any help would be sooo apreciated
Old 14th April 2007, 03:41 AM   #2
On Hiatus
SY's Avatar
Welcome to the world of tone controls!
If you can measure frequency response, this would be a good and educational time to do so. Ck may have far less effect than you think until you make it big enough to defeat its own purpose.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th April 2007, 03:19 PM   #3
alexmoose's Avatar
okay, I have no fancy equipment or anything, however Another tube-head and I got together with some sweeps, and tones and saw which frequencies appeard to be dropping out. It appears that anything below ~80hz is just soft, quiet, and fluffy.
Old 14th April 2007, 08:14 PM   #4
alexmoose's Avatar
Will anything bad happen if I just start playing around with this? because I think that is what I am going to do, just play around...
Old 14th April 2007, 10:24 PM   #5
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Also, think of frequency dependent load of the amp by capacitors across the speaker...
Nothing is bad in getting an experience. But as soon as you've asked we are answering.
The Devil is not so terrible as his math model is!
Old 14th April 2007, 11:22 PM   #6
rdf is offline rdf  Canada
rdf's Avatar
Consider a little resistance (50-75 ohms) between Cf and Ck to start. You won't lose much degeneration and the amp will see a much friendlier load.
Old 14th April 2007, 11:42 PM   #7
alexmoose's Avatar
does anyone have any idea where to start picking CK anf CF values?
Old 15th April 2007, 12:46 AM   #8
Wavebourn's Avatar
I would suggest to start from desired curve of dependence of gain on frequency.
Old 15th April 2007, 04:09 AM   #9
alexmoose's Avatar
Okay, this is what I am thinking now However I need to figure out the impedance of this system so I can pick values.
Old 15th April 2007, 04:41 AM   #10
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
keep in mind the frequencies with more feedback will have less gain. So you will have to add gain to the low freq's somewhere upstream.
A thought on Cathode feedbackHide this!Advertise here!
Cathode Feedback from Secondary for PP Amp gingertube Tubes / Valves 22 2nd July 2009 12:45 AM
Cathode feedback on the simple SE ixe13 Tubelab 0 24th April 2009 12:52 AM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
Cathode Feedback How-To? sorenj07 Tubes / Valves 4 23rd October 2007 06:04 AM
Cathode feedback mark_titano Tubes / Valves 20 11th August 2005 02:56 AM
Copyright ©1999-2017 diyAudio
