Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th May 2018, 09:49 PM   #1
Pooch is offline Pooch  United States
Default Diode blew, SE
After listening to the sweetest sounds I've ever heard from my TSE 45, for almost a year, diode 2 went south. Any ideas on why this would happen after so long? What else should I be on the lookout for? I found out when it blew a2 amp sloblow fuse.
Old 20th May 2018, 11:21 PM   #2
rayma is offline rayma  United States
Is this the FRED diode for the negative supply? Maybe not enough heat sinking.
Old 21st May 2018, 01:48 AM   #3
Bias supply, -150V, so I'm guessing yes. Don't remember it calling for a heat sink, but I can sure add one, can't hurt.
Diode blew, SEHide this!Advertise here!
Mosfet with inverted parallel diode or zener diode nonprof Car Audio 4 23rd October 2015 03:18 AM
Used too weak diode, fuse blew. Welcome Tubes / Valves 14 19th July 2015 04:08 PM
Parallel diode vs antiparallel diode phieuxuatkho Class D 6 31st October 2010 12:54 PM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
