Trying to get my SSE up and running, have a question on the wiring. The diagram shows two wires connected to the input jacks, continuing to the volume control, then to the board. There is only one point to solder a wire on the inputs, do I solder two wires to the same input connection and bring them through the volume control and to the board? Hope this made sense. Thanks for your help!
Check out Tubelab's web site. There are 5 input solder eyelets. The middle three are all ground.
Connectors | Tubelab
Hope this helps.
Michael
Hope this helps.
Michael
