Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 3rd February 2018, 10:00 PM   #1
MrJackson is offline MrJackson  Romania
Default TSE headphone amp
Hey guys and gals,
After having great success (albeit with a lot of work) with the 6SN7 Aikido kit from Glassware, I want to try my luck with a new tube project. This time, I want a "purist" SE headphone amp. After reading a lot on the Tubelab site, I decided 01A tubes would work fine for me. Also, I'm thinking 5AR4 rectifier.
I would have it work with some regular Audio Technica 32ohm cans and, maybe sometime in the future, a pair of HifiMan or Audeze LCD-2s. For these, I'm not sure I would actually need a separate tap on the OT - advice would be welcomed.
Right now, I'm trying to make a sort of project plan and put together a BOM. I was eyeing a Hammond 369AX (B+ and filament) and an 266M5 (rectifier filament).
As for the OT, I'm considering Electra-Print (going all out)... 5K:32, maybe silver wire.
I'd appreciate your advice/opinions on this plan, before I shell out the cash on something that won't work in my setup.
C
Old 27th February 2018, 05:11 PM   #2
So... no-one?
Old 27th February 2018, 08:42 PM   #3
randytsuch is offline randytsuch
Electra print makes nice iron, but shipping from US would probably be expensive.
If I was in Romania, I'd consider guys like Lundahl or Sowter. And I'm sure there are others in the EU that can wind good iron for your application.
For this project, I'd just keep in mind the impedance and sensitivity for any cans you might use with this amp. Hifiman cans tend to be less sensitive, so need more power to drive them.
In general, no reason you can't use a TSE to drive cans with the right iron.
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 11th March 2018, 05:18 PM   #4
Hey Randy,
Thanks for chiming in. I'll have a look at what options Lundahl and Sowter offer - I'm not keen on ElectraPrint, but reading about on tubelab made it stick in my head.
Still, I can't decide if I should get multiple taps on the OT. Should I get 32 and 64ohms? Or try to use the 32 for Audeze's LCDs and try to get a higher impedance tap for other cans? I would think that multiple taps will drive the price up considerably, but at the same time I'd try to future-proof it as much as possible... I can't say what cans I'll get in the future.
Old 12th March 2018, 10:07 PM   #5
moggi1964 is offline moggi1964  England
moggi1964's Avatar
James do multiple taps on some of their range. Pretty too! Don't think they go to 32 ohm but I haven't checked.
Pioneer XCHM86. Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 & Genesis II. WIP: Tubelab SE 300b
Old 12th March 2018, 10:28 PM   #6
Pretty indeed... but I just read they stopped doing business.
Old 12th March 2018, 11:25 PM   #7
Originally Posted by MrJackson View Post
Hey Randy,
Yeah, that is what makes it hard. If you want to try Senns later, they have much higher impedance.
multiple secondaries
Per the link above (from a really smart transformer guy), making a transformer with multiple secondaries may be the key here.
I remember a post somewhere where for cans someone recommended 3 or 4 eight ohm taps, I think its three.
Then you connect them depending on the output impedance you need.
Randy
My system is here
Old 13th March 2018, 09:49 PM   #8
That was a very informative link. It's obvious now that the best solution would be to have a multi-tap OT, but choosing the values is a very difficult problem.
I now wonder if going with "classic" tubes (300B or 45) together with an 8ohm OT, while adapting it for headphones (8ohm load resistor + pot) would work sufficiently well for this. It would make for a simpler build that's for sure...
TSE headphone ampHide this!Advertise here!
FS: The Wire headphone SE-SE headphone amplifier ulogin Swap Meet 23 30th January 2018 09:01 PM
Headphone Impedance and headphone amplifier TheGimp Tubes / Valves 89 3rd May 2014 01:46 PM
headphone amps vs headphone inputs? awangotango Headphone Systems 7 13th October 2012 01:36 AM
Headphone tap argonrepublic Solid State 2 31st January 2010 06:05 PM
ESL Headphone X-former bjackson Planars & Exotics 5 19th September 2005 03:45 AM
