Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th January 2018, 02:49 PM   #11
DaMuffinMan is offline DaMuffinMan  United States
Thanks colnago55, are the 5AR4 / GZ34 basically the same tube or are there any differences?
Old 5th January 2018, 06:11 PM   #12
colnago55 is offline colnago55  United States
Yes, my understanding is they are the same tube. Just two different numbering systems.
Eastern bloc versus Western?
Old 6th January 2018, 04:39 PM   #13
How does this look spec wise for a power switch? https://www.digikey.com/product-deta...131-ND/1718576
Old 6th January 2018, 05:38 PM   #14
I've used this one a few times. I like having the flange to connect it to the chassis. It seems very similar to the one you have selected
764-00/003 Qualtek | Connectors, Interconnects | DigiKey
Old 6th January 2018, 08:11 PM   #15
After I get the amp running I want to add some meters to it. How hard would it be to wire in some of the VU meters as seen on this Mcintosh MC2102 .
And 1 more question, I want to make a face-plate something like the one on the
Mcintosh MC2102
that will allow a color to come through (green on the Mac) instead of having the face-plate engraved. Any suggestions?
Old 10th January 2018, 04:19 AM   #16
Well I went ahead and order most of the parts from Digikey and all about tubes, we will see what happens.
Old 12th January 2018, 01:26 AM   #17
I am ready to order the Big Iron. I am getting the Edcor CXSE25-5K. If I remember correctly I have to specify Secondary (Output) Impedance * of 8 Ω is this correct? Here is the link Thanks
EDCOR - CXSE25-5K
Old 12th January 2018, 02:05 AM   #18
Hannibal 8 is offline Hannibal 8  United States
If your speakers are 8 Ω then yes.
Old 12th January 2018, 02:33 AM   #19
Yes, thanks Hannibal 8,,
Is this the correct part for R14 & R24 ? 3 Watt Metal Oxide Power Resistor
| TubeDepot.com
and then I select 10k in the dropdown? And then do
I select 150K for R2 ?
Old 12th January 2018, 03:07 AM   #20
Yes on the values but I didn't see an option for 150K in the dropdown. I ordered mine at either DigiKey or Mouser - can't remember which - so that I could specify the manufacturer. Dont know where you are located but I'm in the Midwest and I get things from DigiKey really quickly.
Bout Time SSE Build now Starting need helpHide this!Advertise here!
Starting a SSE build neomat Tubelab 43 28th November 2016 08:52 PM
starting to build my own sound system dub music Parts 0 29th August 2015 06:57 PM
Starting an F1 for the first time... Donovad Pass Labs 11 23rd February 2010 02:30 PM
