Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 28th October 2017, 04:02 PM   #1
Mark Fugate is offline Mark Fugate
Default TSE 300B Initial checkout problems. Help please.
I am building a TSE with 300B tubes and the initial checkout is not going well.
My B+ 457 Volts, 5842 plate voltage is also 457 Volts, and R5 (270 Ohm 2W) glows red.
My power transformer is an Edcor XPWR131-120 with the following wiring
W 330 V CT T1-1
Y2.5 V T1-2
Y 2.5 V T1-3
R 330 V T1-4
O 330 V T1-5
BR 3.15 V T1-6
WBR 3.15 V CT T1-7
BR 3.15 V T1-8
Thanks much in advance for any and all assistance.
Old 28th October 2017, 04:10 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
R5 is your negative bias supply and only feeds C6 and R6. Check C6 is the correct way around.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 28th October 2017, 07:03 PM   #3
C6 and C7 are correctly oriented,
Any other thoughts?
Old 28th October 2017, 08:15 PM   #4
To make R5 heat up there is obviously a heavy load. The resistor following is 10k so it is either a solder bridge on C6 end, or it is magic. Nothing else can cause that.
Old 28th October 2017, 08:18 PM   #5
Maybe a bad C6?
I replaced the 270 ohm resistor, powered things up, and C6 started smoking.
Old 28th October 2017, 08:20 PM   #6
Could a shorted C6 cause me to see full B+ (450+ Volts) on the 5842s?
Thanks much for your comments.
Old 28th October 2017, 08:23 PM   #7
If C6 is short, you will have no negative bias and the output valve will complain by getting extremely hot very quickly.
Full HT on the anode of the 5842s is a bias issue on those valves. If they are not biased correctly, (turned off) full HT will be on the anodes.
Sort out your -ve bias voltage first. One step at a time.
Old 28th October 2017, 08:26 PM   #8
Have you got -200volts roughly on C6?
Old 28th October 2017, 08:43 PM   #9
-508 which seems impossible. I will recheck. Confirmed.
The voltage across R7 is 0
Old 28th October 2017, 09:04 PM   #10
Check your wiring, C6 must have no more than about 220v ish, certainly not 508!
TSE 300B Initial checkout problems.  Help please.Hide this!Advertise here!
SSE problems during checkout measurements jjrider Tubelab 2 24th August 2015 11:53 AM
High B+ at initial checkout phase on SE moggi1964 Tubelab 13 27th May 2014 03:17 PM
Tubelab SE initial testing problems. Help thommo007 Tubelab 10 15th June 2012 08:09 AM
Final checkout problems with Tubelab SE Mazuki Tubelab 11 21st June 2009 12:50 AM
Electro Harmonix 300b...shorting problems? crispycircuit Tubes / Valves 8 30th November 2007 05:09 PM
