Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 28th October 2017, 09:40 PM   #11
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Looking at your chosen transformer, 330 0 330 will give you around 500volts so maybe a change of value for R5 to drop the voltage to a useable level.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 28th October 2017, 10:10 PM   #12
Mark Fugate is offline Mark Fugate
What if I use 330 0 260?
I must add that I appreciate your patience and willingness to help.
Old 28th October 2017, 11:41 PM   #13
colnago55 is offline colnago55  United States
I think you wiring is wrong. I'm using the same transformer for my 300B.
On mine the two brown wires are in the 7 & 8 slots and the brown and white in the six slot.
Otherwise I believe we match up.
good luck.
Old 29th October 2017, 12:26 AM   #14
Thanks guys!
Old 29th October 2017, 04:57 PM   #15
Gentlemen,
I just changed my transformer secondary to 260-0-260 and I now have B+ = 414 Volts and B- = -195.
I also changed the filament wiring as suggested by calnago55.
I still do not think that I am out of the woods because all other forum posts I find for 300B TSE use the 330-0-330 windings.
Old 29th October 2017, 05:49 PM   #16
I 'think', (KEYWORD 'Think') things may be working since making the transformer change.
It puzzles me that I can not find anyone else using the secondary windings that I am using.
Any thoughts, comments, and ideas are greatly appreciated.
Old 30th October 2017, 06:54 PM   #17
mkane77g is offline mkane77g  United States
Always Learning
TSE 300B Initial checkout problems.  Help please.
voltage checks don't lie
Old 30th October 2017, 07:06 PM   #18
I am using the 330 taps on the same transformer and my B+ is around 360. My 5842's are set at 175.
I'm using a choke and a motor run capacitor.
What is your set up?
Old 1st November 2017, 04:36 PM   #19
mkane77g - you are absolutely correct! I neglected to check my variac output and as you have guessed, the variac output was 141 volts.
Color a deep and very bright shade of 'stupid'.
Thanks again guys
TSE 300B Initial checkout problems.  Help please.Hide this!Advertise here!
SSE problems during checkout measurements jjrider Tubelab 2 24th August 2015 11:53 AM
High B+ at initial checkout phase on SE moggi1964 Tubelab 13 27th May 2014 03:17 PM
Tubelab SE initial testing problems. Help thommo007 Tubelab 10 15th June 2012 08:09 AM
Final checkout problems with Tubelab SE Mazuki Tubelab 11 21st June 2009 12:50 AM
Electro Harmonix 300b...shorting problems? crispycircuit Tubes / Valves 8 30th November 2007 05:09 PM
