Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 18th October 2017, 05:48 PM   #1
Cifte12AU7 is offline Cifte12AU7  United States
Default Knockout punch sizes
I found a local place that will rent me a Greenlee hyrdaulic knockout punch kit.
The dies rent separately so I wanted to rent as few dies as possible to keep costs contained.
The tube sockets will sit below the aluminum surface of the chassis so I need to accommodate not for socket diameter size but for maximum tube glass diameter.
If I'm building the Tubelab SSE I would think that I would need the following punch sizes for my aluminum chassis:
1. 2 1/2" to accommodate the KT66 (largerst power tube): max diameter is 53mm or 2.08 inches
2. 1 1/4" to accommodate the nine pin 12at7: max diameter is 7/8"
3. 2" to accommodate the GZ-34 or 5AR4: max diameter is 1.5"
Am I accurate? I was concerned about going any smaller because it could make rolling/twisting tubes on exit difficult.
Thanks in advance for any insight!
Old 18th October 2017, 06:53 PM   #2
PDL is offline PDL  United States
Don't forget, knock-outs are sized as NPT sizes which are not the same as actual inch measurements.
Old 18th October 2017, 07:01 PM   #3
rayma is online now rayma  United States
That's to allow for the clamp to be inserted through the hole and tightened on the cable.
You may be able to buy several punches for the cost of the tool rental.
Hydraulic Punch Driver w/ 5 Hydraulic Punches & Dies
Knockout Punch Kit 10 Pc
Old 18th October 2017, 10:18 PM   #4
Thanks guys. I'll need to reconcile my measurements with the knockout punch sizes. Now, I'm leaning towards buying so I can ensure I don't make any mistakes.
Knockout punch sizesHide this!Advertise here!
Punch 250M vs Punch 500M seankane Car Audio 30 26th January 2016 12:35 PM
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 01:17 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 07:52 PM
Sizes of ESLs JoeBob Planars & Exotics 1 1st June 2004 05:14 PM
