Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th October 2017, 01:26 PM   #1
first_1st is offline first_1st  Thailand
Send a message via MSN to first_1st
Default TSE45 change to TSE2A3
Now I had finishes TSE45 if I want to change output tube from 45 to 2A3
How to do?
Thank you.
Old 5th October 2017, 07:24 PM   #2
mkane77g is offline mkane77g  United States
Always Learning
Depending on which power transformer you have it could be just a rectifier change. Output transformers won't be optimum but it it will work. Need to set bias.
Old 6th October 2017, 05:44 AM   #3
For Power Transwer I use Edcore Xpwr131.
If I want to try 2a3 for temp . Can I change 45 to 2A3 by not change any parts ?
Old 6th October 2017, 01:31 PM   #4
Always Learning
Sure you can. I tried this myself using modern 2a3's and had lot's of hum. And I'm trying this exercise right now. Setting the bias as I type
Old 6th October 2017, 02:06 PM   #5
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
The hum you experienced was likely because the filament regulator on the board was operating on the edge of dropout. For the regulator to be hum free the voltage across C1 needs to be 3.3 to 4 volts. Sometimes a big cap in parallel with C1 helps.
The 2A3 draws 2.5 amps nominal from a 2.5 volt source for the filament. This is right at the limit for the 5 amp regulator on the TSE board. Some "modern" 2A3's draw more than 2.5 amps, while some draw less. I have not tested any 2A3's in 6 or 8 years so I can't say which is which any more with certainty.
The XPWR 131 was created by another forum member for 45's and 300B's but 2A3 operation was never intended for that transformer. The 6.3 volt winding is only rated for 4 amps. At the time Edcor stated that they could not offer a 6 amp or so 6.3 volt winding on that sized core.
My 2A3 amp used a Hammond 272JX transformer, but this was done over 10 years ago. I have been told that modern versions of this transformer put out too much high voltage, but I haven't tried it myself.
To use 2A3's in a TSE board you need a 6.3 volt CT winding that can provide 6 amps or more. This could come from a separate transformer.
The heat sinking on the regulator chip will need to be upgraded. I used an old CPU heat sink from a Pentium 1 chip (yeah it was a while ago).
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 6th October 2017, 02:18 PM   #6
Always Learning
Sounds nice. Doing FM upstairs.
Old 6th October 2017, 02:20 PM   #7
Always Learning
And after reading Georges post this experiment will stop.
Old 6th October 2017, 03:41 PM   #8
If it works.....
The filament regulator will simple shut down if it gets too hot. Obvious symptoms, loss of sound. It just fades out as the filaments go dark. Usually power cycling is needed to restore operation, but sometimes the regulator will restart once it cools off. In this case check the heat sink. If it's too hot to touch (after you have pulled the power plug) add some additional heat sinking.
Check your power transformer. Again if it's too hot to touch an upgrade is needed.
Note, this is the usual rule of thumb. My original Lexan TSE has its second power transformer. The original transformer got really wet during a hurricane, and still lived for a year despite being full of rust inside (determined by autopsy). The second power transformer is a "too small" Allied 6K56VG (made by Hammond) which gets too hot to touch and starts to smell funny after several hours of continuous play with 300B's, yet lives on. Over 10 years now however most use has been with NX483's (5 volt 45's).
Old 6th October 2017, 05:30 PM   #9
Always Learning
Well then the 2a3's will go back in. without the top cover on it may keep cool. Onwards.
Old 6th October 2017, 05:54 PM   #10
Always Learning
3.34v @ C1
TSE45 change to TSE2A3Hide this!Advertise here!
first time build TSE45 need help first_1st Tubelab 35 6th June 2017 04:08 PM
How much to set Bias on TSE45 first_1st Tubelab 3 2nd May 2017 03:39 PM
Power transformer for TSE45 first_1st Tubelab 3 19th April 2017 01:02 AM
If I change B+ do I have to change the circuit? nige838 Tubes / Valves 3 18th August 2011 11:16 AM
Change nafanja Swap Meet 2 14th April 2008 09:40 AM
