Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 17th May 2018, 10:05 PM   #21
pitchinwedge is offline pitchinwedge  United States
Originally Posted by akimmet View Post
Your new diagram looks correct, another way to correctly install a snubber is in parallel with your load (the power transformer). However, your calculated values are off. A common combination is a .1uF X2 safety capacitor in series with a 4.7R 1W resistor.
Most importantly the capacitor needs to be at least X2 rated, this will help avoid catastrophic failure of the capacitor. Older amps commonly used 2500V ceramic capacitors and they were known to occasionally blow apart.
Gads, those formulas must be way off! Anyways, I found some parts based on your comment. Will these work?
0.1F 20% 400VAC Ceramic Capacitor Y5V (F) Radial, Disc
4.7 Ohms 5% 1W Through Hole Resistor Axial Flame Proof, Fusible, Safety Wirewound
Thanks for the help!
Old 19th May 2018, 01:05 PM   #22
akimmet is offline akimmet  United States
You neglected to mention if the capacitor you chose is safety rated. Make sure the capacitor you chose is X1 or X2 rated! Your snubber needs to absorb voltage transients in excess of 1000V, a standard 400V capacitor is likely to fail.
In .1uF, X2 film capacitors are usually much less expensive than X2 Ceramic capacitors.
Old 19th May 2018, 02:11 PM   #23
Yes, the spec sheets rated X2 for 1500v. Thanks again, will try to install it next week.
Power switch optionsHide this!Advertise here!
Amcron DC300A replace power switch with 2 wire switch simondolanbass Solid State 3 11th September 2017 01:07 AM
B1 Power Supply Options rgheck Pass Labs 47 20th November 2014 07:11 PM
Capacitor Across Power Switch to Control Switch On Noise? DreadPirate Analog Line Level 20 21st April 2013 02:58 PM
Power switch driver board(Momentary switch) + output relay board(delayed ON/fast OFF) Neutrality Headphone Systems 1 20th March 2013 10:57 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Resources saved on this page: MySQL 66.67% / PHP 34.31%
