Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th March 2018, 10:48 PM   #11
DaMuffinMan is offline DaMuffinMan  United States
Pitchinwedge, which ones did you decide on?
Old 9th March 2018, 11:02 PM   #12
pitchinwedge is offline pitchinwedge  United States
I want to order this 5A/250VAC switch.
30mm Momentary or latching 1no1nc Ring LED Anti Vandal Push Button Switch 6V, 12V, 24V, 110V, 220V-in Switches from Home Improvement on Aliexpress.com | Alibaba Group
Seems to me it should work but would like some reassurance
Old 15th May 2018, 04:45 PM   #13
I realized during final assembly that I don't have specs for the illumination LED on the switch described in my previous post. I've sent an email to the vendor, but in the meantime, I hooked up the switch w/o illumination. Thankfully, the power on/off works as expected.
When I ordered the switch, I assumed it could be installed the same way as the lighted switch on my IEC power entry module. Now I'm not so sure. The pin configuration makes me believe the LED is most likely 5V or 12V DC.
The switch has 6 terminals: 2 for NO, 2 for NC, one +, and one -. Assuming I'm correct about it being DC, any suggestions on how to make the LED connections?
Old 16th May 2018, 04:30 PM   #14
akimmet is offline akimmet  United States
Did you order the switch from the alibaba page from your previous post? If so, most of the specs were in the order page. Depending on what you selected when you ordered, the LED will have a built in dropping resistor for 6v, 12v, 24v, 110v, or 220v. If you selected a lower voltage than you wanted to use, you will need to add another drop resistor and a diode to prevent exceeding the PIV rating of the internal LED.
I also highly recommend installing a RC snubber across the switch contacts if you havenít already.
Old 16th May 2018, 07:06 PM   #15
Ah that makes sense. There is some shrink tubing on one of the LED terminals and I think a resistor is hiding underneath. Household voltage is 110v, but I ordered 220v, and the vendor says the LED is rated for 250v.
RC snubber sounds like a good idea but I've no idea how to implement. The little I understand from Google searching is that a resistor and capacitor is needed? Would I connect as shown in the image? What values would I use?
Old 17th May 2018, 05:18 AM   #16
The 220v version is likely work with 110v, it will just be a little dim.
The snubber is recommended because your power switch will likely live a short an unhappy life without one. More important than anything else, any capacitor placed on the mains must be safety rated for that purpose.
Old 17th May 2018, 04:23 PM   #17
I just found a solution online. Schematic confirms my previous drawing and simple formulas provided based on voltage and current:
Rs=V/I
Cs=1/((V^2)∗switching freq)
So, calculate using 120V, 4A, and 1 for switch freq:
Rs=30ohms
Cs=39uF
Look ok?
Old 17th May 2018, 05:12 PM   #18
PDL is offline PDL  United States
Your drawing is not correct. Snubbers go across switches, not in series with them.
Old 17th May 2018, 06:32 PM   #19
Thanks for the correction. How does it look now?
Old 17th May 2018, 07:33 PM   #20
Your new diagram looks correct, another way to correctly install a snubber is in parallel with your load (the power transformer). However, your calculated values are off. A common combination is a .1uF X2 safety capacitor in series with a 4.7R 1W resistor.
Most importantly the capacitor needs to be at least X2 rated, this will help avoid catastrophic failure of the capacitor. Older amps commonly used 2500V ceramic capacitors and they were known to occasionally blow apart.
Power switch optionsHide this!Advertise here!
Amcron DC300A replace power switch with 2 wire switch simondolanbass Solid State 3 11th September 2017 01:07 AM
B1 Power Supply Options rgheck Pass Labs 47 20th November 2014 07:11 PM
Capacitor Across Power Switch to Control Switch On Noise? DreadPirate Analog Line Level 20 21st April 2013 02:58 PM
Power switch driver board(Momentary switch) + output relay board(delayed ON/fast OFF) Neutrality Headphone Systems 1 20th March 2013 10:57 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
