Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd September 2017, 07:22 PM   #1
canersahin is offline canersahin  Turkey
Default PT options
Hello everyone,
It's been a very long time and i still couldn't finish my Tubelab SE amp Things were crazy. Anyway I have a question.
I am living in Turkey right now so I ordered James Audio PT, which works with 220v.
However, next month I am moving to Los Angeles, CA. And hopefully I can finish my amp there . I don't think my 220v James Audio PT will work there right? Is there a way to make it work there? Or should i just get a new one?
Thanks.
Old 2nd September 2017, 08:55 PM   #2
zman01 is offline zman01  Bangladesh
PT options
Can you check if your James power transformer has dual primary option - supports both 115V and 230V mains?
Old 2nd September 2017, 10:09 PM   #3
That is an excellent question. Unfortunately i lost the connection diagram. But i see 110v on the PT.
My PT's model is JS-9612-2 maybe someone else has the diagram and kind enough to upload it here?
I uploaded the specs
File Type: jpg Screen Shot 2017-09-03 at 12.08.12 AM.jpg (19.1 KB, 100 views)
Old 2nd September 2017, 10:48 PM   #4
I found the wiring diagram. Which says i can get 110v. Would it work in the States?
Old 2nd September 2017, 11:30 PM   #5
mkane77g is offline mkane77g  United States
Always Learning
PT options
it should
Old 3rd September 2017, 09:06 AM   #6
I guess I am so lucky that expensive PT also works with 110v Wikipedia says US wall voltage is 120v. I hope i wont blow something
Old 3rd September 2017, 09:17 AM   #7
PT options
That's why I asked to check. Some power transformers (especially more expensive models) support multiple primary voltages. Looked like you picked a winner.
Old 3rd September 2017, 10:17 AM   #8
Hahah yeah without knowing it But i am so glad i am moving to the States because shipping cost of electronic items is killing me... Plus the taxes. I will be in DIY heaven lol
Old 3rd September 2017, 11:42 AM   #9
PT options
Look forward to updates on DIY projects.
Old 3rd September 2017, 02:46 PM   #10
w5jag is offline w5jag  United States
It may be a little higher or lower than 120v. I've seen mine as high as 126, and it usually runs about 122.
The voltages out of the transformer will be slightly higher when 120 ish is applied to the 110 primary. It probably won't be a problem on the high voltage secondary, but it may push your filament voltage up close to 7 volts.
You'll just have to take some measurements when you get here and see where you're at. Might want to leave room on / in your chassis for a small filament transformer to buck the line voltage if it looks like the voltages out of your transformer are too high, or just use a separate filament transformer made for 120 volt primary.
Much less expensive than buying as new PT!
Win W5JAG
PT optionsHide this!Advertise here!
need help on options jeff0172 Everything Else 17 23rd September 2015 01:45 AM
So many options! Please help! unaHm Multi-Way 9 15th December 2013 06:00 AM
options for turntables ksporry Analogue Source 7 13th February 2011 04:14 AM
options please brucegseidner Power Supplies 3 5th February 2010 02:39 AM
Opinions on Options hotscot Chip Amps 6 24th January 2007 02:39 PM
