Power transformer for TSE45
I'm beginner on tube amp Now I start to this project to matching with my new paper mache horn from John Inlow.
I decide to go on TSE45 Now already order TSE board from George yesterday.
I not find Transformer spec to use with this board on his website.
Anyone can me the transformer spec to use with 45
325v-CT-325v 250 mA
5v-5V 3A
6.3V-ct-6.3V 6A
use choke Triad c-14x
is it ok to use this transformer spec for TSE45 ? Please suggest.
for output Tranformer now I plan to go ELETRAPrint
if I want to upgrade C5 150uf 450v to oil cap what value I should go on?
Thank you everyone.
Sawadee..... The Edcor XPWR131 (XPWR131) was designed to be used with the TSE board in all the different builds possible.
You can find the info here.... Universal Power Transformer
I imagine the shipping will not be inexpensive though.
You can use a 100uf and 50uf motor run caps in parallel to get the 150uf... The cap is shown as 100uf on the schematic.
The value of this cap is not as important as the quality of the cap.
Sawadee Denny,
for XPWR131 I can use this power Transformer for all tube (45/2A3/300B)right?
How to use it
Schematic | Tubelab
(330-260-0-260-330) at 175mA center tapped, 6.3V (3.15-0-3.15) at 4A center tapped and 5V (2.5-0-2.5) at 3A center tapped.
330v/260v in T1-4,T1-1(CT),T1-5 330v/260V
if I use #45 i must use 330V right?
T1-2 ,T1-3 T1-8,T1-6,T1-7which votage that I use 3.5v or 2.5v
So sorry for my dummy question.
