It's quite simple. Plug your multi meter into the speaker jacks for starters. Use input plugs on the input side. This could be a piece of wire bent into a U shape. One side inserted into left input, the other side into the right. Multi meter set to AC volts to take measurement.
Easy as s walk in a park
Thanks.
