Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th March 2017, 07:35 PM   #1
waltroman is offline waltroman  United States
Default terminal strips
can anyone get me a source for the terminal strips used on the SSE. Any recommendations for correct size for the TSE.
Old 20th March 2017, 08:29 PM   #2
colnago55 is offline colnago55  United States
I used a ten position terminal block and a four position one for my TSE. The ten was to connect the power transformer and the four position for the outputs.
NTE 25-B500-10 10 Pole 20A Panel Mount Barrier Terminal Strip
Old 21st March 2017, 12:41 AM   #3
I was hoping to use the through hole type connectors found in the SSE. Still looking for 1-2 and 3 position blocks with a 10mm spacing.
Old 21st March 2017, 12:50 AM   #4
I don't think the board was made for them. I don't think they fit on the TSE board.
Old 21st March 2017, 01:09 AM   #5
mkane77g is offline mkane77g  United States
Always Learning
terminal strips
I haven't found any
Old 23rd March 2017, 02:10 AM   #6
The hole spacing is 5mm. I found some on Digikey in two position. I figure where needed I could cut the pin off of to use in the single holes for the two output transformers. I plan on connecting the center taps for the HV and 6.3 to a single chassis ground point and grounding the board and rca's to a 10 12 watt resistor to the same point.
Old 24th March 2017, 01:45 AM   #7
Please ecuse me the hole spacing is 10mm. Like below
ED200/3DS On Shore Technology Inc. | Connectors, Interconnects | DigiKey
and these
http://www.digikey.com/product-detai...D1615-ND/33910
terminal stripsHide this!Advertise here!
Terminal Strips: Thumbs Up Or Down? BillEpstein Tubelab 6 13th December 2014 05:19 PM
2 wires for Return Terminal and 1 wire for (+) Terminal in EXPENSIVE Headphone cable Hallucinogen Headphone Systems 14 24th April 2014 09:21 PM
Mounting terminal strips to blank copper board musical noise Construction Tips 9 16th June 2011 07:32 PM
Where Do You Buy Your Terminal Strips? sdclc126 Multi-Way 5 5th June 2007 02:35 PM
Tektronix Silver/Ceramic Terminal/Barrier Strips For Sale Or Trade valveitude Swap Meet 0 23rd January 2006 03:26 AM
Copyright ©1999-2017 diyAudio
