Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 14th March 2017, 10:54 PM   #11
waltroman is offline waltroman  United States
Originally Posted by Osvaldo de Banfield View Post
I don't find any relation between two facts. Output transformers doesn't give any heaters supply. Noise is electrical or acoustic?
Also, 10% variation in heater's voltage is tolerable.
I believe the noise to be electrical. The reason for mentioning the voltage on the 6.3 volt tap was that is seemed higher than when I first checked it.
So I am left with 2 issues. the voltage I believe I can fix with a higher ohm rated resistor on C3.
Old 15th March 2017, 01:26 AM   #12
I found this thread and am interested in the 2.2uF caps for the output transformer. Can someone verify the B+ tap for the output transformer. I believe they are T3-2 and T2-2
click to follow down to #5
TSE buzz and PSU
Old 15th March 2017, 02:45 PM   #13
mkane77g is offline mkane77g  United States
Always Learning
Noise at output transformers
post #6
terminal input/output for SE Board
Old 15th March 2017, 03:00 PM   #14
Thanks for the help but that is the power transformer not output transformer.
Old 15th March 2017, 03:13 PM   #15
Always Learning
Then you have it correct in your post #12. Don't think it makes a difference if it's T3-2/T2-2 or the other way around. The difference I have noticed is the soundstage, the way it's presented. One way it's a real centered image. The other way the image is more right left or way outside of speaker placement and my preference. sort of 3D if you will.
Old 15th March 2017, 04:00 PM   #16
I am a little confused. T2 and T3 are the two output transformers. The output transformers fit between the 10 ohm resistor on one side and the plate of the 45 tube on the other. Do I understand you correctly saying installing the 2.2uF cap in either position to ground will change the soundstage dimension?
If so what would give the large soundstage?
Thank for the reply.
Old 15th March 2017, 08:42 PM   #17
Always Learning
No. Your post, #12 asking to verify B+ tap is all I am alluding to.
Old 16th March 2017, 01:52 AM   #18
Got it, either side of output transformer is OK just different presentation.
Are you doing this to get rid of noise?
Old 16th March 2017, 02:18 AM   #19
Always Learning
I have no noise.
Old 28th March 2017, 12:14 AM   #20
A friend with a scope found cold solder joint on C1. Amp runs dead Quiet now!
Noise at output transformersHide this!Advertise here!
transformers and noise Bibio Power Supplies 3 28th March 2014 06:51 PM
Looking for a decent pair of 807(output tube) output transformers hatrack71 Swap Meet 4 5th April 2012 08:43 PM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
Noise floor rise on heathkit W4-AMs when power supply transformers were swapped terminatorx Tubes / Valves 4 8th October 2006 02:31 AM
Copyright ©1999-2017 diyAudio
