Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th September 2017, 04:42 PM   #21
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Sorry for not being around much....life gets in the way. Did you ever get this working?
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 19th September 2017, 09:41 PM   #22
craigtone is offline craigtone  United States
craigtone's Avatar
No ... it just sits on the floor collecting dust
I have yet to pull the legs of the bias circuit. The poor board has been soldered and re-soldered so many times replacing FETs and re-touching all the joints I am afraid to apply heat yet again.
Craigtone Audio
Soundsmith Boheme, WT Classic, Craigtone Très Phono, Apollo-R, D100 Mk2, Craigtone Axiom Preamp, TSE 45, ALK Klipschorns
Old 20th September 2017, 12:02 AM   #23
mkane77g is offline mkane77g  United States
Always Learning
TSE Help!
If it were me I would go thru the entire build procedure visually and make sure everything is correct.
Old 20th September 2017, 12:56 AM   #24
I can't figure out where to go from here based on the information available.
I have only done this twice in 12 years so far, but it might be time for number three. If you send it to me I WILL make it work at no cost to you other than shipping.
#1 was a case where the builder had run about 6 inches of wire from the board to his 300B sockets which were mounted on a slab of marble. The whole amp had turned into a giant oscillator / radio transmitter. I had to add ferrite beads and multiple stopper resistors top calm the beast.
#2 was an SSE which turned out to be not so simple. The troubleshooting thread had grown to a dozen pages or so with several experienced tech trying to solve the dead channel. The builder had drilled out the holes in the PCB to accommodate the fat leads on his specialized coupling caps. This broke the plated through hole connections from the top of the board to the bottom killing the signal.
#3 ???
If this works for you, send me a PM and we will work out the details.
I would prefer the board only. I have several power transformers to use, some OPT's and several sets of old 45's that work. This avoids the expense of shipping a whole amp, but I can deal with the whole amp too, Michigan isn't too far away, so shipping shouldn't be too expensive, but UPS here tends to break things, then claim that they weren't packaged properly.
Old 23rd October 2017, 09:33 PM   #25
It's ALIVE!
Admittedly a rather low Fi setup, especially those trendy Radio Shack speakers from 1980, but it the best that I can do right now. It took me much longer than I expected to find things like my box of 5842's and a suitable set of OPT's, but I found all sorts of missing things in the process like a long lost guitar amp, and some OPT's that I had forgotten about. These things haven't been seen since I lived in Florida, more than three years and two moves ago.
has been playing for a couple hours and there were NO dead parts.
Old 23rd October 2017, 09:44 PM   #26
craigtone's Avatar
It's ALIVE!
Awesome! What was the culprit?
Craigtone Audio
Old 23rd October 2017, 10:00 PM   #27
It was so obvious that I missed it until I powered it up and starting poking around with a voltmeter and found no drain voltage on the mosfets. There is a wire jumper that supplies this voltage. It was not installed. This was not visible in the photo that you had posted since it is on the other side of the board.
I will unhook and pack the board up and send it back to you tomorrow or Wednesday.
Old 24th October 2017, 12:02 AM   #28
Always Learning
TSE Help!
Old 24th October 2017, 12:09 AM   #29
w5jag is offline w5jag  United States
So, this design feature allows one to pull that jumper and isolate the B+ to the power tubes, from the rest of the board?
In other words, higher than ordinary voltage for the power tubes, e.g. 811 ish voltage, could go to the BPLUS pad, regular "low" B+ voltage to the DRV_B+ pad?
Win W5JAG
Old 24th October 2017, 01:16 AM   #30
Always Learning
TSE Help!
Is that what those resistors are doing @ R18?
TSE Help!Hide this!Advertise here!
When to adjust B+ TSE Guarnera Tubelab 5 16th April 2014 02:08 PM
TSE C6? Guarnera Tubelab 2 19th February 2014 03:55 PM
TSE input jrobson Tubelab 7 9th December 2012 04:33 PM
TSE question.. Green77 Tubelab 17 28th September 2012 07:50 PM
TSE help evanc Tubelab 2 12th June 2012 10:14 AM
