Help me source a toroid PT for 300b SE amp - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 27th February 2017, 06:16 PM   #1
asilker is offline asilker  United States
asilker's Avatar
Default Help me source a toroid PT for 300b SE amp
Hey folks. I picked up a pair of Plitron OPT's for the SE amp. I'd like to use a toroidal power transformer to match. Could you help me choose one?
Here again are the specs for what I'll need: "The power transformer needs to provide about 640 or 650 volts center tapped at 150 mA or more, 5 volts at 2 amps, and 6.3 volts at 4 amps. A center tap on the 6.3 volt winding is NOT required. The Hammond 276X will work. I have been using some surplus power transformers that are 660 VCT. They give me about 390 volts of B+."
Thanks for your time and patience
WTB: Toroid PT for LM3875 project ( 2x22v, ~200VA) Magnetmaz Swap Meet 5 7th May 2015 06:14 PM
GU50 SE vs 300B SE tube amp?? gaborbela Tubes / Valves 72 16th October 2014 01:27 AM
DC on toroid PT windings audiowize Tubes / Valves 10 4th October 2009 03:41 AM
Proximity of toroid PT from Gainclone boards limono Chip Amps 13 7th January 2009 12:32 AM
Toroid PT question audiowize Tubes / Valves 10 5th January 2009 08:02 PM
Copyright 1999-2017 diyAudio
