Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd March 2017, 04:50 PM   #31
Atk1d is offline Atk1d  Canada
Default Update
Hi all, After some time spent on this forum and critical analysis of the amp I solved it.
I have discovered that the volt meters I had installed were impeding the signal flow.
I temporarily disconnected them. Re tested the amp and it works and sound way better distortion free and loud.
Now one concern I have and it is the same in my first see the right channel seems to run at a lower volume then the left. ( When possible I've been adjusting balance thru player) to compensate.
Has anyone else noticed this, After all the recent checks I've done, pouring over schematic and parts, nothing is jumping out at me. Any clues?
Thanks.
Old 2nd March 2017, 08:27 PM   #32
Default Whew, got it
Well I re wired the opt disabled the panel meters and
Jammed Ac/DC back in black on Vinyl.
All gear is assemble by me.
Old 2nd March 2017, 10:10 PM   #33
moggi1964 is offline moggi1964  England
moggi1964's Avatar
Odd that the meters would cause such an issue as others seem to have had good luck with them.
Glad you got everything working and a nice looking build.
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 3rd March 2017, 01:18 AM   #34
mkane77g is offline mkane77g  United States
Always Learning
PT Help.
whewwwww
PT Help.Hide this!Advertise here!
need a little help with identification PT lordraptor1 Power Supplies 11 1st January 2016 08:16 AM
Northlake PT ?? bereanbill Tubes / Valves 2 22nd May 2009 04:16 AM
pt longji98 Tubes / Valves 12 31st October 2008 03:48 PM
PT Cardinal ErikdeBest Digital Source 18 26th October 2004 02:16 PM
Bridged amp pt.2 Gabevee Solid State 1 24th July 2002 04:11 PM
Copyright ©1999-2017 diyAudio
